OK the bike landed at 6:30. It looks great but it weighs in at just under 26 kilos on my scales, anyway I am going back to bed now.
Hi, we based the weight on the delivery note from the manufacturer which states 23kg for each bike. Here's a scan of the relevant line below for our first two sample bikes:Back to the weight issue, I see that the 50cycles website has just been changed to read bike weight 23Kg, battery weight 2.4Kg and the total weight has been removed this makes a total of 25.4Kg which is in the ballpark of the weight Daniel recorded on the 53cm medium framed modelNext will be frame sizes I supose.
I think an apology on the website to all those who have been mislead regarding frame size and weight would be the least they could do.
John
Or change the seat post for a rigid one, which I'd prefer anyway. It's already fitted with a comfort saddle, so scarcely needs seat post springing, which never operates on my 11 stones/70 kilos anyway.However if you like to be able to put both feet on the ground when seated you need to be 5 foot 8 minimum in my opinion.
Daniel
There's never been a published photo of me anywhere in my lifetime, giving rise to postings drawing parallels with The Stig.On a slightly different tack I thougt Flecc looked taller than 5'6" in his A to B Photo![]()
John
I am 5' 6" tall with a 28 inch inside leg (that's why I have trouble getting trousers to fit me)The one that they were supposed to be bringing to me to try out had better be a smaller one, since I'm 5' 6" too. That size of frame and a test will hardly be possible without a change to a rigid seat stem.
I think 50Cycles should take responsibility for what they post on their website - I've said so before.Back to the weight issue, I see that the 50cycles website has just been changed to read bike weight 23Kg, battery weight 2.4Kg and the total weight has been removed this makes a total of 25.4Kg which is in the ballpark of the weight Daniel recorded on the 53cm medium framed modelNext will be frame sizes I supose.
John
Same problem Derrick, same height, inside leg between 28" and 29", but with a seamstress mother I learnt to sew and use sewing machines at a very early age, so can correct the trousers.I am 5' 6" tall with a 28 inch inside leg (that's why I have trouble getting trousers to fit me)
Derrick - Llanberis
