3,411
It has crossed my mind, but money is getting tight
The only advanage of a pre-pay meter is immediate control, so you might end up saving money straightaway using electric blankets and sleeping bags.
I have ordered a higher tog duvet.
Adding a cheap 99p space blanket layer inside the duvet cover, transforms a duvet's heat insulation. But does make it much more flammable.
it's hard to use my game controller with winter gloves on lol
If you tighten the sleeping bag drawstring under your armpits, you can still play games. Otherwise inhabit the bag.
6 injections a day puts me off wrapping up
Use it as one would normally use an under body electric blanket on the bed, without being enclosed.
The sleeping bag has a zip, easy to climb in and out of, plus you don't have to be inside it completely: over legs, up to mid, up to armpits, over head - it has possibilities.
Feeling cold? Gas bills high? You need a 40W GuerneyWarmerator™ Lite!
3,411
heat just bleeds out, once I turn the heating off our place goes down to 17 degs in 10 mins
I spend most of my time in the living room, and the windows there get cold wind blasted- very thick curtains weren't enough, but once I added Ikea thermal blackout blinds, it now maintains 21C for ages after the heating has been turned off. I installed them so they roll down a bit proud of the curtains, down to a couple of inches above the floor.
8,844
6,733
needs more fire power :p
Hydrogen has the second lowest boiling point and melting points of all substances, second only to helium. Hydrogen is a liquid below its boiling point of 20 K (–423 ºF; –253 ºC) and a solid below its melting point of 14 K (–434 ºF; –259 ºC) and atmospheric pressure. Obviously, these temperatures are extremely low.
49803
8.4ghz and it crashed.
3,411
But they made great music.
3,411
Didn't know these lethal tiles are still available , worse fire hazard ever to stick on the ceiling.
There are versions which claim to be fire resistant:
Suspended ceiling panels are safer, supposed to be fire retardant, but a standard suspended ceiling could leave @PC2017 stooping around his home, if his ceilings are already low - perhaps the more fire retardant heat insulating suspended ceiling panels, could be screwed directly to the ceilings? Or maybe he could install suspended ceilings with smaller heat insulating air gaps? Onto 2x2 inch wood perhaps? I suspect he's probably losing much more heat via the windows: Until I fitted very thick curtains, and thermal roller blinds over my windows, foan around doors and draught excluders under them, heat would be pushed through and out of my home by strong winds (also breezes).
It's a pity laminate floor underlay is flammble, cheap insulation for ceilings otherwise? A few layers and painted?
Rockwool panels?
Reactions: PC2017
3,411
One guy locally on the nextdoor forum was moaning about his monthly bill being £600, god knows what they are using sounds like they are trying to heat a barn up.
Is he paying it forward, backwards, or is he being screwed sideways? When I eat at a restaurant in the summer, it's nice that I don't pay in advance for food I might eat in winter.
Som folks have no rational on how to economise or be thrifty.
You'd be amazed how often people who use food banks, continue to order expensive takeaway meals.
3,411
8,844
My guess is also those pleading poverty still suscribe to rediculous over priced monthly TV services and moile phones, then don't get me started on cigarettes and booze.
Reactions: esuark and flecc
jimriley
619
413
You have to think of the children though...
...addicted to netflix, booze and fags!
Reactions: PC2017 and flecc
PC2017
1,338
338
Scunthorpe
Two people one netflix HD £11ish a month for us, I watch and enjoy every day & i cancelled my TV license which was a waste of money imo YT for news now. Mobile phone £30 per year, old S6 1p mobile if anyone's interested, no landline & fibre 32mbps £23 a month, I do have a cheeky screwdriver every night. Quit smoking 10 year ago.
matthewslack
2,595
1,672
Rockwool panels?
Insulated plasterboard is the straightforward way to add substantially to thermal performance for walls and ceilings I.e. internal room surfaces.
This is what happens in Scotland to hard to heat homes like old stone croft houses, and to various categories of qualifying benefits receiving households, it is free.
The two houses I have seen insulated in this way are transformed from freezing to more cosy than a new build.
Other suppliers are available.
Reactions: robert44
6,733
3,411
A hotel in Moscow we stayed at in 1984 had double glazing panels with a 2 inch gap between glass panes. Triple glazed. Minus double digits outside but warm hotel - for some reason the water was yellow. So yellow it stained the ceramic sinks etc. Must have been yellow for years.
8,844
Probably plumbed the urinals into the supply water to save wasting it .
Reactions: Croxden and flecc
3,411
That explains all the vomting on the (propeller driven) Aeroflop Aeroflot plane afterwards - people were erupting every few minutes, vomit dribbling down the aisle and side to side as the plane violently rocked about... or it could have been the very suspicious looking "Chicken cocktail" in wineglasses (pronounced "Ticken"). Teeny tiny bits of chicken in a pink ooze. Served with a slice of gone off lemon. Everything was served with a slice of old lemon, even the tea. I drank a lot of black tea, ate nothing for the entire 36 hour flight.
But very impressive triple glazing. The Moscow airport ceiling also impressed - loads of huge (copper?) metal rings of various lengths pointed down. Soldiers with rifles, big furry hats and long dark green wool coats were everywhere. Also the view flying over the Himalayas at dawn was awesome, but bloody cold.
Reactions: PC2017
3,411
I have no ceiling insulation or good cavity insulation, heat just bleeds out, once I turn the heating off our place goes down to 17 degs in 10 mins
I'm having to waterproof my padded cycling leather jacket again - wax doesn't melt and soak in, unless I keep my home very hot for a day or two; applying three or so layers. Hence 24 degrees centigrade, which is now easy to maintain after getting my home insulated. 27C is also easy (but unbearable). Deffo get your home insulated! More cold snaps, must surely be on the way?
49806
I might have to open windows...
3,411
Energy companies want boosted access to emergency £40bn government backed support. Nationalise! :mad:
PC2017
1,338
338
Scunthorpe
Or Chernobyl's impact spread further than one could imagine.
