Hi d8vwh
Thanks for that. Hopefully the supplied kit will deal with a standard non-alternating pole switch. Coming myself from an industry which predominantly used fully customisable aftermarket vehicle ECU's, it would be nice for the OD kit to allow input configurations within the handlebar controller to enable the user to select the logic protocol for the users inputs. I fully understand why OD try to make the kit as PnP as possible but if they could add the programming ability (which would not be a lot of effort) it would take an already top notch kit to the next level. It wouldn't just have to end at brake and crank sensor inputs, it could extend to battery voltage and inclination sensors etc to allow greater flexibility. It would also be good if crank rpm could be monitored (rather than it seems with most kits a simple on/off PA) so that power could be delivered progressively, especially from a standstill.
Bearing in mind the retail nature of these kits, warranty issues will of course be ringing in sellers heads but if the seller was to 'lock' a sub menu which could only be accesed via a disclaimer then I see no issues. For sure, if we were using a fully mappable ECU and popped a £40k engine due to mapping/setup error we would be on our own.
These are just a few things I have picked up from my Mrs kit which is just a regular bafung ebay jobbie but hey I am probably getting a bit carried away.
Looking foward to getting the OD kit and playing with it
