Ok sure, a quick summary wouldn't go amiss
Bike is a 2011 Trek FX 7.5.
The motor is now a Cute 100, which has replaced the Tongxin used originally. Nothing wrong with the Tongxin but I was getting fed up "baby sitting" it - it's nice to just be able to throttle up from a stand still with the Cute 100, where as the Tonginx used to slip it's clutch.
Controller is a Lyen Mini Monster Sensored Mk II (changed from the mini Monster sensorless - the Cute 100 didn't like the sensorless controller and used to stutter).
Battery is a 63v 12ah unit, made up of 9 4000mah Zippy 25 Compact lipo packs, connected in 3p15s config using an IceCube harness. Each group of three paralleled packs has the balance JST-XH connectors paralleled up as well. I've encased it in carbon fibre and it lives in a cycleezee bag. It weighs bang on 5kg.
Charging is primarily via a modified NES-350-48 power suplpy unit, current modded to put out 7.75amps and cut off at 62.25v (4.15v per cell). It's a simple one plug connection to charge and takes around 1.5hrs to charge after a normal commute (putting back between 7.5ah and 8.5ah on average). So far, I have NEVER had to balance the pack using my hobby charger and all cells are staying within 20mv and that's 80 charges so far. I also religiously stick to the "80% DoD" rule and I've never taken more that 9ah out of the pack. If balancing is required I can just unplug the end of the harness and plug in the parallel dapter and balance charge on the hobby charger.
Regards performance, it'll cruise along at 25mph with a neutral wind and 22/23mph into a reasonable headwind and I've seen 30mph with a good tailwind. I pedal all the time, but not that vigourously (unless I'm trying to mess with someones strava segment
). Watts per mile is averaging out at about 22 watts/mile so range is 25miles on max speed setting, which is more than enough for my commute of 19miles.
Fastest commute is:-
Workout Details - SportyPal
Same commute in the car is 30 mins as a minimum - up to 50 mins it's summer or Blackpool clowncil are digging up the prom road again!
Bike is fitted with a three speed switch, position 1 is set to 16mph, which I used around peds when the prom is busy, speed 2 which I use to extend range or when there is a stiff headwind or it's really cold (doing 25mph in sub zero temps things get a bit nippy) and speed 3 is set to 115% - which is 25mph assuming neutral wind.
Power is 800watts peak which the cute 100 seems to be handling no probs - nice acceleration, nice assist up the couple of hills I have (only 200m long each) and I've ever only had the motor warm to the tocuh - I've measured it at 55c at it's hottest - well within spec.
The bike is fitted with a "failsafe". If I'm more than 1m from the bike, the bike defaults to, and cannot be brought out of, speed setting 1 - or 16mph. Motor is stamped "250w".
All in the bike weighs 21kg and that includes a tough rack, full mudguards, lights, toolset and pump.
I'm averaging 4 rides a week with my longest unbroken streak being 3 weeks every day at the end of August.
The bike has covered 5000miles in 15 months and saved me approx £1900 in fuel costs alone. I haven't kepts a track of how much the bike has cost me though! I've only replaced the brake blocks and I'm just about to change the chain for the first time - as it's just reached the 0.75 limit. Brakes are about to be upgraded with a pair of Magura HS33 Hydraulics that I got for £40 from a friend at work - used three times in the dry!
