Computers and stuff...
6,733
i have never seen a pair of the pro studio ones for sale 2nd hand ever where you can move the tweeter.
i have used the scm 150s and pused them to the limit but for low end there really flat frq response so needs the sub.
gold silver rolex and speakers is what to invest in :p
3,410
Pop in and see them suited and booted, make a positive personal impression. Don't count on email. Take your CV with you, look ready to start work immediately. Don't leave your CV at reception, ask to speak face to face with the recruiter. Use social engineering.
6,733
id not work there for the little money they offer when you cant afford the products they make and sell from what they pay you per hr.
they wont price match funky junk either :rolleyes:
3,410
You can do it if you don't live anywhere, eat, or wear anything. Easier to get loans with a regular paycheque...
6,733
i have used the scm 150s in a studio there just to midi for me as lf crossover is to high so you need a sub for dnb ect
53213
6,733
10 years ago you could have got some atc speakers for half the new price they are today :eek:
i only paid £1500 each for my genelecs and the vat back then was 15%
6,733
3,410
Is he shouting because he's been deafened?
The mid-range is king for mastering, no matter the genre. Just get a pair of these cheap copies of classics:
6,733
i have used those speakers in 2002 for low end stuff you need the sub just listen to the tracks there all mid crazy not even my bass drivers are moving lol.
he needs a 4k 55inc tv and run it as main monitor from the imac and get a celling mount for it and run it from one of the tunderbolt ports on the imac.
i got 2 on mine :p
6,733
track 5 sounds best with my hd 650s but bass is still to low on my genelecs mids will be screaming at me b4 the bass drivers moved lol.
3,410
Copy the general freq distribution of commercially produced music (you'll see these days, almost everything under 20hz is killed, to maximise volume of everything else), or your favourite music tracks - I use this for reference, for quick and dirty masterings. Anything serious gets processed by a pro:
6,733
if your room has no acoustic treatment and the speakers not calibrated to the room they could cost 100k like the hi end pmc that's 100k.
you cant master anything with plugins you need 3 way monitors that matches the freq response you like and a room to match it.
ie you build the studio around the monitors.
53219
4 subs should have got the dual 18inc for the front ;)
3,410
Dyson Singapore.
6,733
every pic i take just get fkn worse lol
6,733
6,733
SPECIFICATIONS
Speaker typeCustom-built 80" woofer with dual 21" voice coil
Xmax35 mm excursion each direction, voice coil remaining in homogeneous magnetic field, linear and lowest distortion
Passive | ActivePassive, rack mount 2 x 10.000 Watt AES67 DSP/Amplifier included
Principle Sealed
SPLCalculated data example, custom enclosure dependent
145 dB cont. / 148 dB peak
138 dB @20 Hz
114 dB @5 Hz
Frequency RangeCalculated data example, custom enclosure dependent
1Hz - 100Hz
Efficiency105 dB / 1W/m
Power handling20.000 W
ImpedanceDual Voice Coil, 4 Ω each
Air volume displacement172 L / in comparison 21" standard cinema subwoofer 1,76 L
DimensionComplete custom design of enclosure for desired installation, for dealer/contractor build locally, minimum 10 m³
Weight 80" Woofer573 lbs | 260 kg
53250
Reactions: guerney and Woosh
3,410
6,733
6,733
6,733
postage rings and glue was £22.85 ;)
