Computers and stuff...
3,411
"This is the 1031A from Genelec's datasheet which has thus far matched other measurements quite closely. "
3,411
My cheapo VRM gadget has an acoustic model of your speakers:
6,733
1031a are 2 way monitors my 1038s are tuned to my room pita with out the amp rack mount :)
6,733
the inner part that glues to the cone has its angle set already
6,733
if you want the ars back to original you need the smooth D and not W like on my drivers
6,733
3,411
"Battery: 3 * AAA battery or 1 * 18650 (not included) "
6,733
i got 18650s ;)
3,411
Practice makes perfect. Find round stuff to rotate, accurately squirt and spread similarly thick glue neatly around etc.
6,733
6,733
no wonder why they wont give me the service manual fkn thing is glued together fkn wankers ill get in there one way or the other :mad:
3,411
A hot air gun would probably cause damage.
6,733
it is either glue or some sort of sealant cos it wont fkn move be a fkn mission if i have to take them off the stands as will have to take the hole room apart :rolleyes:
3,411
Seems mad if it's not designed to be serviced! Why use bolts if they're going to glue it permanently? My guess is hot glue, but whatever they've used must have dried to a brittle state by now. It'd be easy to scratch, bend or otherwise permanently damage the fascia using brute force. If those were my speakers, I'd lay them flat face up, then gently but thoroughly heat just that area using an electric blanket for several hours (shouldn't get hotter than 60 degrees C) , then tap it lightly all over the edges with a rubber mallet (cover the fascia with a thick cloth to protect it from the rubber mallet) to loosen things up a little, then try again to pry it apart using plastic prys only. If that didn't work, I'd heat again using the electric blanklet, plus use a hot air gun afterwards, risking damage - using a very low setting (start with 100 degrees C), over one corner to start with.
