- 36 month free / up to 60 month prorate
- CCA: 900
- CA: 1080
- Minutes Reserve Capacity: 185
- Battery Gasses Need To Be Vented To Outside
- Battery Located In Trunk
- Group Size (BCI): 49
- Cold Cranking Amps (CCA): 900 CCA
- Cranking Amps (CA): 1080 CA
- Reserve Capacity (min): 185 Minute
- Voltage (V): 12 Volt
- Length (In): 13-15/16 Inch
- Width (In): 6-7/8 Inch
- Height (In): 7-1/2 Inch
- Weight (Lbs): 55 Lbs.
- Terminal Type: Top Post
The 900a is the cold cranking amps as above.
