My Cargo bike build.
3,411
No change, the jar doesn't even open with x2 L click or single R click. Just the a black box that shuts immiedately.
It won't shut down immediately if you use the command line -you'll see what the error message actually is.
3,411
The command:
cd C:TSDZ2-Smart-EBike-1-20.1C
...puts you into the "dist" directory, as stated in the ReadmeJava.txt file.
Then hit enter. Then type:
java -jar "JavaConfigurator.jar"
Then hit enter.
3,411
At this point, we have no idea what the configurator is complaining about!
3,411
Well, it's all a wonderful opportunity to learn more about computers (than you previously wanted or needed to).
3,411
Your vesrion of the bat file doesn't have that line to correct, Bike4Two had a different version of bat file
Yours is calling on another compile_and_flash.bat file, which is in the folder called "controller"
3,411
PATH = %PATH%;C:\STMicroelectronics\st_toolset\stvp;"C:\Program Files (x86)\STMicroelectronics\st_toolset\stvp"
so it's set paths to two directories, just in case.
3,411
So you can do the same as Bike4Two:
3,411
Edit:
file in the folder called "controller", hit save and start the configurator.
3,411
Basically the programmer has linked one .bat file to another, that's all - batch files can often be linked together like that to run multiple groups of commands.
3,411
You'll never find me if anything goes wrong... ;)
3,411
Remember to close down the configutaor until you've edited and saved that file. Start it again after editing and saving.
6,733
i think he has hung himself with the usb cable lol
3,411
Nah, I'm sure he'll be ok. I know doctors who feel completely out of their depth when trying to work their PC. Microsoft don't make computers easy to use to do anything useful anymore. Hidden file extensions, zip folders which look like folders, a zillion other things... Windows 10 is a mess.
3,411
People really tend to freak out seeing the command prompt - just don't type in certain commands which will wipe everyting, and you'll be ok.
6,733
format c:/ :p
3,411
Windows 10's Notepad should be fine editing that .bat file. If it looks like gobbledigook, just get Notepad++ and use that instead. It's what I use for pretty much everything.
3,411
What worries me is that we can't see the error message - when you use the command line, we will.
3,411
If it looks like this, use Notepad++
46916
Related Articles
