Looking for a decent ebike to buy, on a bit of a 'budget'
Mr. B Ikeman
24
FIrst off, I'll state that the highest I'll go is £1700, maybe £2k if it was an absolute bargain bike down from more than double that.
Though I'd rather stay under 1.5k
Reason I'm looking for an ebike is because I need to build up strength in my legs, I live in a fairly hilly area >20 degree inclines and want to get out to some good cycling spots. Having an electric assist would make it less torturous getting around.
I've been looking at the cyclotricity kits (full frame, 70%) and have been asking about one specific model, their high end full suspension 1500W model (high wattage for off road use), however when I asked for info on assembly (ie do I need to size the chain, will I need to use a chain splitter, does it come with a pre-sized chain and quick link) they just directed me to their PDF, which doesn't cover that. I'd also asked in the same email for a set of specs on the forks, brakes and rear shocks, derailleur and shifters as their site just lists "Air shocks" "Hydraulic brakes" which isn't exactly a heap of information, they never provided that info which makes me feel they're being a bit cagey. Am I wrong?
Cyclotricity seem to be the best I've found since they check two of the main boxes I need them to; throttle and high wattage motors, for use on offroad/private land then the option to set a road legal 250W lockout.
Hub drive seems to be my only option, from my limited knowledge, for an ebike that can do throttle + PAS, even retrofitting a throttle to a mid drive sounds like it may be impossible on higher end motors as the ESC is built into the motor itself, so can't really be changed out to accept a throttle as well as PAS.
If you could give me a list of options I'd have in my budget range that fit the criteria of:
Has throttle + PAS
Can climb inclines of 20-25 degrees
Is a good bike overall, or not absolutely awful
I'd appreciate it. I've been out of cycling for about 8 years now and this is my first foray into ebikes.
3,344
A handlebar button enabled hypersensitive pedal assist mode could be implemented for torque-sensored systems too. Should be legal, because the pedals would need to be used for it to provide assistance. It'd stop all those torque sensored dudes moaning about throttles being illegal.
pedalling; noun: pedaling
the action of working the pedals of a bicycle.
3,732
Oh come on, it was supposed to be funny, but in retrospect, it really wasn't. Are you saying your bike has a hypersensitive pedal assist mode which starts with a 1° rotation of the cranks, enabled/disabled by a button on the handlebar as described in the post above? People wouldn't be endlessly moaning about throttles, if they had a pedal assist mode which operated like that.
Yes, more or less. It's not 1 deg, but close enough.
There's another way you can get what you want by mechanical means. Mount a derailleur idler sprocket on a thumb throttle and fix the device to the chainsaw so that the sprocket rests on the upper chain run. The spring will hold the chain down. As soon as you apply force to the pedal, the chain will tighten, lift the sprocket and operate the throttle, so the amount of throttle you get depends on how hard you press the pedals. You can have it enabled/disabled with a simple switch so that it doesn't interfere with normal PAS function.
If you want it simpler, you only need a switch and a spring (like a motorbike brake switch) connected to a simple lever with the sprocket on it, operated by the tension in the upper chain run. IIRC, there was a bike that used that system to operate the pedal assist, but it was a long time ago and I can't remember the details.
3,344
Anyone can move rotate or jerk the crank arm by 1 degree, even uphill, and with max current and programmed very long motor run-on, it'd of course be ever easier to keep pedalling. For the toque sensored dudes, assistance at max current could start with a bumblebee fart, hypersensitivity permitting? Or multiply measured torque while the button is depressed, revert to normal when it cheers up.
3,344
So you can't use it on bendy roads, got it.
Doesn't really sound fit for purpose as a throttle though.
The only pedal you want at 6 is the offside pedal. inside pedal in that position is dangerous.
I've made the mistake of going into a(in this instance) a left hand tight bend with the left hand pedal in the 6 o clock position, it hit the ground and , well basically lifted the entire bike up and both wheels disconnected from the ground, and i went on an elbow first road slide.
Nearly ground that elbow to the bone :D
Once clipped, never forgotten! I always make sure the pedal on the leant over side is not nearest the road surface or kerb - who full throttles around bends anyway? Once you rotate the right hand side crank to the 90°/3 O' clock position, you'd be on half-throttle, or none if you touch the ebrake until you've gone around the bend.
I have to keep both pedals level while traversing speedbumps lest I clip one, which reminds me, there ought to be accelerometer activated momentary throttle cutoff when heavy bumps are encountered, as we don't want outcomes of potholes and speed bump encounters becoming any hairier.
Mr. B Ikeman
24
The reasoning is dead simple, and you can have what you want already.
An EAPC is a bicycle, and a bicycle needs the rider to pedal. That's fundamental to the definition: 'Electrically Assisted Pedal Cycle'.
You want a very low powered electric motorbike. Well you can have one, but it then becomes in law an LPM: 'Low Power Moped'. And it needs to go through a one time approval process.
First off the word "Assisted" does not mean you need to be pedalling. Someone in a wheelchair can be assisted by a family member, friend or carer who pushes said wheelchair. Doesn't mean they need to be wheeling themselves around at the same time.
With a throttle it is still a pedal cycle, I'll say this using one with a throttle and I still end up pedalling well over 90% of the time.
A lot of the time I don't use the throttle and I don't need to dick around with pedal assist settings to turn the power to the motor off while pedalling.
Additionally, I've not heard any reasoning as to why throttles are more dangerous, you've said the law and that's about it. Not all laws are well thought out.
as I've said, some unelected individual likely got given a bike worth multiple thousands of pounds with an extremely cutting edge pedal assist and assumed that's what they're all like. Basically the "Buy a Tesla" of the ebike world.
I fitted a pedal assist, it gives power to the motor even when backpedalling. A throttle does not do that. Of course I could spend more on a better controller and pedal assist (and probably will) though a throttle is simple and good for an entry level ebike. Most people aren't going to spend 2k+ on an ebike if it's their first, they'll go for an entry level one, or a kit, which likely comes with a pretty poor pedal assist. Shifting your pedals back at traffic lights and suddenly having the motor come on and send you into moving traffic seems a whole lot more hazardous than being able to get the bike to move by pushing a lever in.
As I've already said, deregulation up to 1HP (750W) would be fine by me, over-regulation in the UK has never improved safety, be it with knives (which just like an ebike, are primarily tools) guns (again, tools; with one specific purpose, putting holes in targets) there was even a plan to ban beer bottles and introduce hardened glasses to stop pub brawls in '97.
Regulation/bans simply don't work and in the case of shoddily made PAS systems, may make things more dangerous. Education would work, which is why a solution would just be a quick visual and written (online or not) course for people who want to cycle 'class 2' ebikes.
The benefits for people with mobility issues would be vast, not to mention the mental health benefits for people who, should they not have a car and have mobility issues, may feel trapped in their own home and we have very recent figures on how people who felt trapped in their own homes responded in terms of mental health; not well at all.
Making cycling more accessible to more people seems like a net benefit to everyone for me.
6,689
anyone got a spare motor and batt so i can make a mobility scooter ? :p
needs more power
62350
6,689
BuzzFeed, Inc. is an American Internet media, news and entertainment company with a focus on digital media. Based in New York City, BuzzFeed was founded in 2006 by Jonah Peretti and John S. Johnson III to focus on tracking viral content.
they said no
6,689
my leg is fooked so need a 1250bhp ebike so if i crash it again i can fit in a bucket or have to go in wheele bin mon night for next day cremation down the PowerStation that burns rubbish for profit. :p
62354
3,344
Which kit is that specifically? Sounds useful - if pedal assist works pedalling backwards, it'd make for easy hill starts. If you have ebrakes, backpedalling pedal assist would be safe?
6,689
nope 12% t1000 titanium leg and hip to go 40 mph on my bike i need 120rpm at cranks.
i was only going 23mph n someone walked out straight in front of me on a fkn phone i should have hit them head on as clipped there ass locked the back brake n next thing i know is my right leg is backwards ko on the grass embankment like hitting a wall.
i broke my pelvis in 3 places
broke my collier bone
broke my thumb
nuked my hip and half my right leg and now have ti rods n bolts 6hr opp as looked like a nuke went off it was like i jumped of a cliff. :oops:
first thing i asked is what happens if i crash again any warranty :p
3,344
Sorry to hear that. I assume you continued cycling so people wouldn't give you funny looks for wearing a helmet in public?
I do wish it was socially acceptable to wear helmets in public at all times, someday it will be when we're all forced to live in hermetically sealed domes and have to wear spacesuits when out walking. I record all of my bike rides with my helmet affiixed GoPro, in case I fancy suing someone for their house... can't have too many houses... great equity... and it'd be great if my helmet could record all of the bizarre shiz I see every day when not cycling. I probably walk about more than most on this forum, some days about 10 miles of pavement between train stations and bus stops. It's mad out there.
Mr. B Ikeman
24
Just an ebay split-disk pedal assist. Single hall sensor.
Would probably be safer to get a gear on your cassette that just isn't attached to the wheel. Gear with a bearing before the splines/threads. That way you could pedal forwards with almost no effort (probably less than backpedalling), a tiny bit of dirt in your drivetrain isn't going to derail the chain and you're not going to have to rely on ebrakes to stop the bike flying off if you adjust the pedals while stopped. You would need to get that freewheeling (in either direction) gear custom machined, though cheap online-order CNC out of mild steel should probably suffice as it's not going to actually see much force.
You would probably have to sacrifice a gear on your cassette though unless there's enough room to sneak an extra on.
Sturmey
693
374
68
There is usually a history to particular laws and its often possible to look up the different debates and contributors and amendments etc. But I think (and correct me if I am wrong as I am no expert) this paragraph goes back to at least the 2002 European directive below which I presume many countries try to stick to and it has more or less stuck despite the documents revision.. I presume it could be changed or individual countries may possibly choose to ignore/modify it .
(h) cycles with pedal assistance which are equipped with an auxiliary electric motor having a maximum continuous rated power of 0,25 kW, of which the output is progressively reduced and finally cut off as the vehicle reaches a speed of 25 km/h, or sooner, if the cyclist stops pedalling,
There was a separate provision for disability scooters etc but I think the speed limit is could be something like 4 or 8 mph.
Bizdustry
15
I haven’t yet published this video on my channel, but I’m due to publish the review in a few hours but the link will work to access the content.
The bike below, retails for under £500 and goes up to 22mph of speed (when you remove the restriction). It also folds up.
Only downside, it’s rather small for larger riders, like myself but perfect budget ebike.
iSCOOTER U4 Review - Electric Bike UNDER £500?!
matthewslack
2,387
1,601
Don't publish links here to content that shows how to break the law.
Reactions: Bizdustry
8,727
Some people just don't get it .
The concession for EAPC's is that they are limited in power and how that power is activated, to be as near as possible to a non assisted push bike .
If folks think they can out put more power then a 250w EAPC then they don't need an EAPC.
If one wants a moped then simply buy one and register and pay the insurance required for a motor vehicle.
