it should work now i didnt publish it ....The video doesn't show on my tablet. Is it a Flash one, which won't show on Andoid devices?
haha yes i pressed the set button for a wihle and i was able to put it higher but it doesnt sound like it is running faster althoug my display says it does .... strange i will try it on the road in a second >>>> is it possible i only have 1 setting in the menu ? i dont see any other options available .... ichanged a number that said 1500 and i up it to 2025 its the max ...Our forum. It looks like the "set" button on yours. I can't remember if it's the power button or a short press of the "set" button to scroll through the menu options when the screen changes to settings. You will soon figure it out.
you are to good to be true .... yes it was wheel size ... and by pushing i get two other menu options but not speed still tryingI don't what that setting is, but it's not the speed. Is it wheel size? The speed should be written as 25 km/h.
ok just tested it ..... it says i m driving 32 .... but still feels like the same ... is it possible i might have broken mofsets with my paperclip[ ? i will test it with my phone to dubble check speed but thank you very much ..... so their is definitly no fail safe
Dammit i found maqnuals online bigstone c300 >>>> i achieve all menus except of course speed menu dam >..... almost going crazy
To get to the advanced settings, you press and hold the set button for a few seconds. When the LCD changes to settings, you press and hold it again for at least 10 seconds until it hanges again. Did you try that?
There's still another trick. If the wheel size doesn't work, the controller must be getting the speed directly from the motor.
The speed signal comes down the white wire from the motor as one 5v pulse each revolution. I see your white wire joins a brown one, which then goes out of the controller. Where does it go?
The idea is to get a pulse at a lower frequency from another sensor. You can take a sensor from a cycle computer. It will have two wires. You cut the white wire from the brown one on your bike and connect one wire from the new sensor to the brown one and the other to any 5v position on the controller where the throttle and PAS get their 5v from. You then glue a magnet to the inside of your crank arm and fix the sensor to a chainstay so that it will pulse with your cadence instead of the wheel rotation.
