January 1, 201412 yr Hello there, I just received BMSbattery parcel and now I'm ready to convert my Dahon jetstream with a BPM: I'd like to reuse the rear wheel freewheel from my Dahon: But for some reason the freewheel removal tool doesn't go inside???? Any idea how to remove it and fit it to the bpm? Thanks I hope to be able to have a ride on a bike ASAP
January 1, 201412 yr It looks like a CST to me not freewheel...the tool is different You can get dnp 8 speeds freewheel from john Pat
January 1, 201412 yr Author what about this freewheel, is it cassette too? So I need a new freewheel?
January 1, 201412 yr Yes it is also You need a new freewheel If you want 11t one I think only dnp is doing it Pat
January 1, 201412 yr Author by the way, I also have sensorless controller, can the BPM work sensorless?
January 1, 201412 yr Yes but it depends how many speed of you jetstream has Dnp has 7,8 or 9 speeds available Also if you are from UK you can get it from john ezee (save the postage and time) http://www.cyclezee.com/ezee-parts-and-kits.html Of course if you want to get something from Paul you can get the freewheel from him Pat Edited January 1, 201412 yr by patpatbut
January 1, 201412 yr Hi cwah, We have some DNP 8 speed 'screw on' freewheels with 11 to 32t for £28 plus postage.
January 1, 201412 yr Yes BPM works either sensorless or hall What speed do you want to run? For high speed I still prefer running sensor Pat Edited January 1, 201412 yr by patpatbut
January 1, 201412 yr Author Hey John, I'm happy to buy from you but you are 50% more expensive than paul even with shipping cost included. I'm also looking for several items: - Empty battery box with mounting plate. As big box as possible I have a massive amount of battery to put inside: http://www.conhismotor.com/UploadFiles/2012/11/2012110804344698018.JPG - Ebike counter and display: 2013 New Display,FDM Ebike Kit,electric bike kit, K LCD3 Display -in Other Sports & Entertainment Products from Sports & Entertainment on Aliexpress.com - Complete disc brake adaptor for dahon jetstream. If you have these, I'd be glad to hear from you Cheers
January 1, 201412 yr Author I'm planning to run it at 74V... but i just didn't want to mess around with hall sensors... But ok I'm going to plug the hall sensor.
January 1, 201412 yr I'm planning to run it at 74V... but i just didn't want to mess around with hall sensors... But ok I'm going to plug the hall sensor. Good. Hope everything goes well Btw, that controller display is very nice, I wish it has watt display as well. Pat
January 1, 201412 yr Author If you check on the right of the screen, there is a writing "motor - W", so maybe there is a watt display. CA is nice, but I really hate the design, it's so big and bulky. Even though it's a good tool.
January 1, 201412 yr Yea how can I miss that. It should be the watt monitor. Do you know what controller does it compatible with? Pat
January 1, 201412 yr Author What I'm looking for is a controller independent display, similar to the CA. I'm trying to get in touch with the seller but he is not answering...
January 1, 201412 yr Hey John, I'm happy to buy from you but you are 50% more expensive than paul even with shipping cost included. Hi cwah, Have you factored in the cost including import duty and VAT? I can't quote for postage without a location.
January 1, 201412 yr A 7 speed free-wheel will be better if you can get one. The Dahon frame is very stiff, and takes a bit of levering to get the 7 speed in. An 8 speed might be too wide. Those LCD displays have various functions in them,but they only work if the controller supports them. The one you showed will only show watts if the controller gives it that information. Did you read this thread? http://endless-sphere.com/forums/viewtopic.php?f=2&t=52619#p781258
January 1, 201412 yr Author Thansk Dave, I'm going to buy a 7 speed then. I'm also received this from BMSBattery: One Bicycle Disc Brake - BMSBATTERY And I'm going to order now: +20mm Disc Rotor Adaptor IS to IS 180mm 7In Hope Magura | eBay And trying to win one of these bids: Avid Juicy 3 set of Front and Rear Hydraulic MTB Brakes | eBay Avid Juicy 3 Three SL Hydraulic Disc Brakes | eBay Is it all right?
January 1, 201412 yr Author Hi cwah, Have you factored in the cost including import duty and VAT? I can't quote for postage without a location. It would be to ship to london. Postcode SE15 4LN. Do you have any empty battery box with mounting plate?: http://www.conhismotor.com/UploadFiles/2012/11/2012110804344698018.JPG Thanks for all
January 2, 201412 yr BMS has this case, just wondering why did you not order it at the same time? Aluminium Battery Case for EBike Carrier - BMSBATTERY Pat
January 2, 201412 yr Author Because battery container have high volumetric size, and shipping cost would be few times higher than the cost of the box. It's the same as importing rim from china. It takes a lot of space so shipping is very expensive on these items
January 2, 201412 yr Perhaps this would get you up and running quickly until you build your own - you could always sell it on later: 2014 Model - 48V 10.4ah bottle holdermount lithium Li-ion electric bike battery | eBay or two of these, in series, mounted on a rear plate: http://www.ebay.co.uk/itm/2014-New-Model-36v-10-4ah-water-bottle-mount-Lithium-ion-electric-bike-battery-/131074514263?pt=UK_Bikes_GL&hash=item1e84a65d57 Edited January 2, 201412 yr by shemozzle999
January 2, 201412 yr dear cwah : this freewheel hub can only use the motor with cassette set, PM me for detail Edited January 10, 201412 yr by rsscott
January 2, 201412 yr A 7 speed free-wheel will be better if you can get one. The Dahon frame is very stiff, and takes a bit of levering to get the 7 speed in. An 8 speed might be too wide. I have fitted an 8 speed DNP to a Jetstream without too much difficulty, please note we include a spacer washer so that it spins freely without contacting the frame.
