That throws a different light on it. I thought that you meant that the screw was coming undone. If i understand right, it's the one that sets the reach, which is the distance between the lever and handlebar, so the piston must be working its way in, which might mean that its leaking internally, or you're losing some oil somewhere. Normally, you can see external leaks from the pipe joints etc. You still need to take the pads out to see if there's oil behind them. Do not operate the brake lever when the pads are out or else the pistons will come out and you'll have a lot of trouble.I just reached the max the screw can go
