Dahon Jetstream conversion
cwah
3,048
179
www.whatonlondon.co.uk
selrahc1992
559
218
this one does seem even simpler:
http://www.aliexpress.com/item/Mountain-bike-stem-lengthen-riser-increased-device-elevator-riser-elevator-20/1540934804.html
but may not make my bike very appealing. But thinking about it.. It would be perfect for folding ability.
And construction does seem robust.
Is the 28.6mm compatible? If so, I'm going to get it.
Thank you
the aliexpress one is certainly highly original, but do you trust that hinge to take all the torsion of throwing ones weight forward against it while braking on a steep descent? I have a friend who has a kalkhoff tasman with what seems to me the perfect low key folding handlebar, will check name next time I see her
Urbanbiker
Mar 29, 2015
Hi, I am new to the forum. @cwah like the SR Suntour suspension fork. I want to do the same, would you be kind enough to guide me what bits(Crown etc) I need to convert the current headset to adapt this suspension fork? Regards.
cwah
3,048
179
Hey yes I installed it but haven't tested... as I had 1 battery stolen and 1 motor non working... I'm not able to do the test on my bike yet.... I'll do a post as soon as I have either a new battery or the motor repaired...
cwah
3,048
179
Finally how it looks now:
It doesn't ride too bad, however it isn't as stable as my 26" mountain bike at 25mph... Hopefully the way I created my battery pack allow me to swap it between bikes :)
I wonder if it's normal? Ideally I'd like to only get a folding bike. It's more compact, saves space and has more torque....
Or maybe I should stick to the bigger bike? Or maybe change my 26" bike with 20" wheel?
Reactions: trex
trex
7,703
2,671
I'd lace a DD motor to a 24" rear wide rim for your 26" bike.
how fast can you ride with the Dahon?
cwah
3,048
179
it goes up to 30mph.. but lack stability at that speed.
Torque is much better than on my 26" wheel that's why I'm considering changing my bigger bike to 20" wheel? 24" may not make much difference.
Why is it lacking stability? I don't understand
trex
7,703
2,671
the moment of inertia of the wheels is proportional to the square of wheel's diameter.
I reckon 24" is about best compromise for 25mph-30mph.
cwah
3,048
179
Why motorbike have small wheel then? they go superfast but their wheel are not massive at all!!
There must be something else in factor??
The lack of stability is probably due to the different geometry of the new fork. As an experiment, you could try it with the forks on backwards. You only need to loosen and rotate the stem.
cwah
3,048
179
but the fork is as high as the previous one so it should be ok? I can try moving the fork backward but i don't think it will make much difference
How do I make sure geometry is right?
Have a read of this:
http://calfeedesign.com/tech-papers/geometry-of-bike-handling/
Your steering axis hadn't changed, except that if your steering head is a different height ftom the ground, it can make a small difference. The thing that has changed is the off-set (rake), which then affects the trail. The bigger the trail, the more high-speed stability you have at the expense of nimbleness for low-speed turns..
It's very difficult to measure these things. The only thing I can suggest is to find a photo of a standard Jetstream taken from the side, then take a similar photo of yours and adjust the size until you can lay one photo on top of the other so that frames are directly on top of each other? You should then be able to see any difference in the wheel position.
The other thing that affects stability is the adjustment of the steering head bearings - too tight or too loose. If you hold the front brake on and push the bike forwards and backwards, and you can feel anybmovement in the steering head, they're too loose. If you lift yhe wheel and the bars can't flop ftom side to side, they're too tight.
Reactions: cwah
cwah
3,048
179
is the conclusion to get a higher rear shock to compensate the trail angle?
cwah
3,048
179
