OK - will put the inner screws back. The outer ones are indeed security torx screws like RobF said. I'll get a set by the end of the week hopefully - at £5 for a full set I can't complain all things considered .. and might be able to get Travelodge windows open with them as a brucie bonus !You don't need that spring thing. It's only extra support for the wire to stop it chafing.
You shouldn't remove the screws around the cassette spline. Only remove the ones around the periphery of the side-plate and then it should pop off if you tap the other end of the axle on the ground holding the wheel.
I don't think it's unnecessary to remove the side-plate from the core because the wiring is on the other side, but you need to remove the cover from the other side that has the magnets in it. For that you need help because the magnets are very strong and keep pulling it down. You must be careful not to damage the magnets especially when putting it back because it tries to jump back on with huge force as soon as it gets close. It's easier with 4 hands.
Sounds that way ... if there's enough of it left I'll probably re-use it just to be on the safe side as a precaution rather than have nothing. Can just shove some shrinkwrap up the cable from the end which will solder into the motor, feed the spring onto the new cable as it's inserted through the axle and shrink it in place beyond the axle end like it was before. Then solder up. I have a drawer full of shrinkwrap of just about every conceivable diameter now, with the exception of the big stuff you put round battery packs.You will be able to salvage the old spring when you remove the old cable.
Count your fingers before you try that bit - And tuck in any dangly bits you don't want prunedApart from the self-pulling together by the magnets, the rest of the re-assembly is dead easy.
I looked at those pics shemozzle999 linked on the Russian website ... silly question maybe, but ... where do the wires solder into and is the axle hollow right the way through from one end to the other with the wires exiting some hole in the middle ?Apart from the self-pulling together by the magnets, the rest of the re-assembly is dead easy.
Good to see you're back on it Alex and seeing it more as just another challenge...these little setbacks as annoying as they are, when you're anxious to get riding, can be useful learning experiences and interesting little challenges in themselves. At least if this happens again to someone else, they'll be able to learn from your postsBlimey ... that was quite an insight ! Really interesting actually. Full credit to him for posting the detailed pics up too - and the bearing size specs. It's this sort of thing which other people can really benefit from if they hit maintenance or other problems.
I've also picked up reading those posts that really need to have the cable pointing downwards exiting the axle hole and should seal with silicone too by the looks of it on both sides to deter water ingress. Hopefully I have some kicking around or else time to get some. There are shelves full of this sort of stuff down in Devon but bare bones only here.
Am a bit muddled by the terminology still (bearings, gaskets, planetary gears etc) and still can't visualize where the magnets actually are - haven't had time yet to sit and study what bits of an electric motor engine refer to what bits of metal in front of meSo be easier once I get those darned screws off and can see.... and also where the wires run on this particular motor for the repair.
I do remember reading a post recently but can't remember the thread where a CST got opened up and was said to be different to a Bafang - but we'll see soon for certain I guess. I'll take some pics once I can get inside the motor.
Where are those darned security torx driver bits.... oh yes - I only ordered them after 5pm today.. itching to get that thing open now !
Not sure what you mean m8, sorrythen double nut the shaft end and gently tap down on the nut to press the end plate off the shaft.
Ah - you tap the axle ... sorry had misunderstood what to tap. Yeah I don't have anything the same diameter so had it on the top of a paint tin on one side and on the top of a step on the other with a pile of rags under to catch it - but couldn't see any nut which could be tapped with a hammer lol.... or two chairs back to back, two piles of bricks or anything like that. Try not to rest on the screw-holes because they might break off. Once you've got something supporting the side-plate, the axle will tap through with gravity helping it, but don't forget to catch the motor if it's got a long way to drop.
This reminds me of those surgeons that do keyhole surgery by remote control from a different location, only they can see what's happening by camera.
I'm not back down there for a while, wurly - am building the bike elsewhere and going to send it down there when I've built it so I've got it to use when I'm there. Far South West of the county.Where in Devon are you Alex?
I have rebuilt a BPM that had a broken shaft. The phase wires will need joining to the windings and lacing/glueing inplace. You will have to pull the stator free of the magnets. Not difficult, but you have to beware of the forces involved. Does the motor have hall sensors?
If you get stuck, i'm in somerset and can give you some assistance to repair it.
