Woosh Sirocco CD or Big Bear?
Jason Scott
92
13
48
I'd go for the Tornado out of those 3 myself. I certainly wouldn't have a CD given the gear change issues.
Aye, I was only considering it because it was the sure fit for a free hanging child seat. The Hamax Caress with Carrier adapter should fit on the Big Bear but until I got hold of both I can't say for sure. Similarly a normal free hanging carrier with some extension tubes might also work on the Big Bear.
The Tornado can be fitted with a rear rack that is suited for disc brake bikes, which I could then attach the Hamax Caress to.
Edit: I'm really surprised that there's so little info about using child seats with ebikes. If we end up getting some and working something out then I'll be posting thorough info here to help others.
Reactions: Ready Eddie
flapajack
114
33
I have a child seat attached to the rear rack of my Giant Lafree. Admittedly I had to tweak the fittings as the normal 2 prongs rod needs to be attached to the verticle seat post tube, which is not available due to the battery. it works fine but is a bit harsh as the natural suspension (spinginess of the 2 prongs rod) has gone but otherwise OK.. Took a bit of tweaking to get it to fit and also not ideal as the set is too horizontal - kind of forcing a more "lean-forward" seating position than I would have like.
Jimod
1,065
634
Polmont
If two bikes have a race, the Bear will win if the rider weighs more than 100kgs, the CD will win if the rider weighs less than 75kgs, between the two weights, they are about equally fast.
The Bear's BPM motor is optimized for weight carrying at low speed, the CD is optimized for high speed or high slope.
I don't understand this. I've never been on a big bear but I've tried my wife's Santana CD. I've got a Kudos Typhoon and I thought the big bear was similar. In any race the With me on both machines, the Typhoon will destroy the Santana. If the big bear is similar to the Typhoon it should also destroy the Santana CD on the flat or up a hill. The Santana Cd was bought for my wife who is disabled and can't pedal. It performs perfectly well for her whereas the Typhoon would be no use at all. I'd think for an able bodied person albeit an unfit person, the big bear would be the winner.
As usual though, you'd need to try them both and buy the one you prefer.
trex
7,703
2,671
the Bear is a brute. It rides like a motobike.
You never need to change from gear 7.
It makes you wonder why you need to pedal at all.
However, I derestricted the bikes to see how fast they went. I was faster on the CDL (24mph pedalling flat out) than on the Bear (22mph flat out) along Southend sea front.
Reactions: CameraDealer
Jimod
1,065
634
Polmont
The OPs post wasn't about de-restricting bikes. I'd still think he'd go faster and climb better on the Bear.
P.S my top speed on the flat with the Typhoon is 35 mph without de-restricting it. ;) mind you, I'll never do it again, I was knackered.
trex
7,703
2,671
35mph is indeed very impressive. I am scared any time I go over 21-22mph.
trex
7,703
2,671
Kudos had a road show last year on the Manifold Trail,in the Derbyshire Peak District,the climbs away from the trail,either side were really steep.
From memory I think we had the Kudos Arriba (BPM rear hub drive)and the KTM Macina Bold (Bosch crank drive)with Nexus hub.
Artstu may remember the event well,it was the ride on the KTM that was the catalyst to go buy the KTM bike.
I must say that I thought at that time that the KTM would be the preferred bike for hill climbing. I was shocked when one of the Pedelec members came back from testing and said that there was something wrong with the KTM and ,if there wasn't ,he would never buy that bike,he said it was like hitting a wall when you tried to change gear and the bike stopped on him- maybe Artstu will respond because he bought that bike.
Since then I have ridden many Bosch crank drive bikes including Cannondale,Scott and KTM,they all exhibit the same riding characteristics,you have to ride them like a normal bike,by that I mean you have to be in the right gear,which means you need to change gear quite often.
Since then we had developed the Kudos Ibex bike which had a strong crank drive motor plus derailleur gears plus many bikes using the BPM hub motor and derailleur gears.
The Ibex suffered from noisy gear changes,especially downshifts uphill with full PAS power,obviously the time when you would be using max PAS.
The Bosch system is clever in detecting high loads in the crank and reducing the power to give the gears a chance to change under lighter load,until they introduced that system it would destroy the Shimaano Nexus hubs and Shimano would not warranty the hubs unless the power under change was reduced.
I found that with Bosch plus derailleur you had to be slick with your gear changes otherwise the loss of power meant the bike almost came to a stop,I found that I changed gear,lost momentum and then found myself again in too high a gear,so changed gear again,it was a negative loop for uphill progress,but with practice it all got quicker. I now understood what the Pedalec member meant back at Derbyshire.
We sold a few Ibex bikes,to experienced cyclists who understood how to accomplish slick gear changes with an appreciation of reducing the chain load before attempting the gear changes. But a newbie to cycling or a lazy rider could destroy the derailleur very quickly-we are sellers of production bikes that have to be user friendly,such a technique was not acceptable.
The addition of the Nuvinci hub to the crank drive overcome the graunchy gear problem completely,gear changes are silk smooth-the bike is effortless to ride and very user friendly but expensive to manufacture,Pedelec newbies love the ease of the Nuvinci hub.
Not long after the Manifold event the Kudos Tornado arrived,shame we did not have it available at the event I am sure it would have been voted the best hill climber. The Tornado and Arriba both have the BPM motor but the torque sensor in the Arriba disguises the low speed grunt of the BPM motor,it's this low speed torque which makes it such an impressive hillclimber.
However,the Arriba is a very intuitive ride,the torque sensor delivering power to match the rider's efforts. In some respects the Arriba has riding characteristics similar to crank drive but without the chain load ,gear change problems and loss of momentum associated with cheap crank drive applications.
I made the decision at that time to build all future Kudos bikes,both MTB and commuter models with this motor,it does everything so well without the complications of crank drive. We went on to build 29" wheeled versions of the Arriba,known as Escape and the Tornado,known as Typhoon-many Pedelecs members have these bikes but are not so regularly contributors to the forum,there are others in the pipeline.
We are now on our third batch of Arriba and Tornado bikes,we have found no reason to change any element of the design.
The technology e-bike race pendulum keeps swinging from Crank to Hub drive and back.Bosch spent a fortune developing their crank unit and a big marketing budget to support it,it should be no surprise that it became the dominant motor supplier but IMHO this BPM motor has swung the race back to hub drive. Having said that these bikes are so much more than just the motor,the KTM range for example are beautifully engineered bikes,whether Bosch crank or Panasonic hub motored.
What the BPM motor allows is small manufacturers like Kudos to produce nice good hill climbing bikes without the marketing or R&D budget of the big manufacturers. With crank drive small manufacturers just don't have the money to fully develop the systems,it sort of reminds me of the difference between cars produced by the kit car industry and those produced by volume car manufacturers.
The trouble with forums such as this is that certain suppliers have friends who are so constantly posting that it makes the forum far from impartial but so many readers are impressed by the weight of postings that excellent bikes like the Tonaro rarely get considered.
Hope the foregoing is of interest.
KudosDave
I re-read carefully what dave posted yesterday. Most of what he wrote I agree with, the excellent Tonaros deserve more exposure, the Bosch bikes can be tricky on hills, small manufacturers do not have the budget to develop sophisticated crank drives and the BPM motor is very good at hill climbing etc. What I don't agree with is the perspective.
The comparison between two comparably priced motors BPM v TCM should really be more balanced. dave of course sells both so he is well placed to comment, I have also tested both systems and give Woosh extensive feedback so I too, am well placed. Dave could be correct in saying that I know Woosh bikes better than Hatti because I bring in a different perspective, from the customers' point of view rather than from the sellers' point of view. My feedback to Woosh over last year resulted in Woosh fitting all their bikes with puncture resist tyres, upgrading the Zoom disc brakes to Tektro Novela and upgrading their batteries to high discharge rate. The differences between dave and I are: I ride a crank drive and he a hub motor, we're also different in shape, I am much lighter than him, nearer half his weight in fact. What we have in common is a modest motor power, I guess that come from our similar age, so speed is not an important aspect in our e-biking.
Personal preferences aside, I think there is no substitute to test rides. Crank drives, cheap bikes and not so cheap bikes, are here to stay.
peerjay56
745
201
Nr Ingleton, N. Yorkshire
You make a good point about the stand. I bought one a couple of years ago and find it invaluable when cleaning the bikes or adjusting the gears etc.
I'm going to try my wife's Santana step through on the stand tomorrow and see if I can suspend it somehow as I need to adjust the gears, it won't go into first.
You can buy a false 'crossbar' from Halfrauds et al that is quick and easy to fit that would allow normal use of a stand. It should be safe; they're designed to allow step throughs to be carried on rear rack mountings on cars. HTH.
As an aside, has anyone else noticed how tetchy many people seem to be on this forum lately? :rolleyes:
CameraDealer
63
14
Bolton
Let us know how you get on with the stand
I tried the Santana on my stand and it works - sort of! You'll see from the picture that there's a sort of mini-crossbar that's just above the level of the chainwheel. On my stand the clamp holds it nicely using that bar. However, I can't rotate the pedals because one of them hits the horizontal arm of the clamp.
I have been able to adjust the gears though by using half a pedal rotation, back pedalling and then forward again. It does work although it's not as satisfactory as a full rotation.
That explains a lot. I couldn't understand why you keep saying that the TCM and 250w BBS01 are better for hill-climbing than a BPM motor. A 25kg sack of sand or two will help explain the difference.
That's OK, I think it's my round anyway, so we can still have a drink together.
JohnCade
1,486
736
Trex do you know if if the Kenda K1047s on the Sport CD are puncture resistant then? I bought this bike only a couple of weeks ago but it has them as well as Zoom brakes not the Tektro Novela.
The Zoom brakes go out of adjustment very quickly on the hills around here too.
trex
7,703
2,671
The K1047 is nylon tyres john. Replace them with MP+ if you want puncture resistance.
JohnCade
1,486
736
So how does that fit in with you saying that they changed them and the other things on the 2014 bikes?
trex
7,703
2,671
they don't always listen to me. I think the next batch of Sport CD (some time in September/October) will have kevlar tyres, 12AH or 15AH battery and detachable mudguards.
JohnCade
1,486
736
I was wondering if they'd sold me an old model. How many deliveries do they get a year then? I would have thought it was more than just one or two.
trex
7,703
2,671
I don't know for sure, but I do know that they run out of stock on the popular models that's why Hatti and Andy could take time off in June. The Sport bikes are not their big sellers though, all the 2014 bikes are painted bluish gunmetal colour.
John F
435
55
That's a shame re the pedals. I think it wouldn't be very well balanced bolting it to that part. I would be a bit nervous. Is it pretty solid?
