Woosh Sirocco CD or Big Bear?
Kudoscycles
Official Trade Member
Apr 15, 2011
5,566
5,048
www.kudoscycles.com
Kudos had a road show last year on the Manifold Trail,in the Derbyshire Peak District,the climbs away from the trail,either side were really steep.
From memory I think we had the Kudos Arriba (BPM rear hub drive)and the KTM Macina Bold (Bosch crank drive)with Nexus hub.
Artstu may remember the event well,it was the ride on the KTM that was the catalyst to go buy the KTM bike.
I must say that I thought at that time that the KTM would be the preferred bike for hill climbing. I was shocked when one of the Pedelec members came back from testing and said that there was something wrong with the KTM and ,if there wasn't ,he would never buy that bike,he said it was like hitting a wall when you tried to change gear and the bike stopped on him- maybe Artstu will respond because he bought that bike.
Since then I have ridden many Bosch crank drive bikes including Cannondale,Scott and KTM,they all exhibit the same riding characteristics,you have to ride them like a normal bike,by that I mean you have to be in the right gear,which means you need to change gear quite often.
Since then we had developed the Kudos Ibex bike which had a strong crank drive motor plus derailleur gears plus many bikes using the BPM hub motor and derailleur gears.
The Ibex suffered from noisy gear changes,especially downshifts uphill with full PAS power,obviously the time when you would be using max PAS.
The Bosch system is clever in detecting high loads in the crank and reducing the power to give the gears a chance to change under lighter load,until they introduced that system it would destroy the Shimaano Nexus hubs and Shimano would not warranty the hubs unless the power under change was reduced.
I found that with Bosch plus derailleur you had to be slick with your gear changes otherwise the loss of power meant the bike almost came to a stop,I found that I changed gear,lost momentum and then found myself again in too high a gear,so changed gear again,it was a negative loop for uphill progress,but with practice it all got quicker. I now understood what the Pedalec member meant back at Derbyshire.
We sold a few Ibex bikes,to experienced cyclists who understood how to accomplish slick gear changes with an appreciation of reducing the chain load before attempting the gear changes. But a newbie to cycling or a lazy rider could destroy the derailleur very quickly-we are sellers of production bikes that have to be user friendly,such a technique was not acceptable.
The addition of the Nuvinci hub to the crank drive overcome the graunchy gear problem completely,gear changes are silk smooth-the bike is effortless to ride and very user friendly but expensive to manufacture,Pedelec newbies love the ease of the Nuvinci hub.
Not long after the Manifold event the Kudos Tornado arrived,shame we did not have it available at the event I am sure it would have been voted the best hill climber. The Tornado and Arriba both have the BPM motor but the torque sensor in the Arriba disguises the low speed grunt of the BPM motor,it's this low speed torque which makes it such an impressive hillclimber.
However,the Arriba is a very intuitive ride,the torque sensor delivering power to match the rider's efforts. In some respects the Arriba has riding characteristics similar to crank drive but without the chain load ,gear change problems and loss of momentum associated with cheap crank drive applications.
I made the decision at that time to build all future Kudos bikes,both MTB and commuter models with this motor,it does everything so well without the complications of crank drive. We went on to build 29" wheeled versions of the Arriba,known as Escape and the Tornado,known as Typhoon-many Pedelecs members have these bikes but are not so regularly contributors to the forum,there are others in the pipeline.
We are now on our third batch of Arriba and Tornado bikes,we have found no reason to change any element of the design.
The technology e-bike race pendulum keeps swinging from Crank to Hub drive and back.Bosch spent a fortune developing their crank unit and a big marketing budget to support it,it should be no surprise that it became the dominant motor supplier but IMHO this BPM motor has swung the race back to hub drive. Having said that these bikes are so much more than just the motor,the KTM range for example are beautifully engineered bikes,whether Bosch crank or Panasonic hub motored.
What the BPM motor allows is small manufacturers like Kudos to produce nice good hill climbing bikes without the marketing or R&D budget of the big manufacturers. With crank drive small manufacturers just don't have the money to fully develop the systems,it sort of reminds me of the difference between cars produced by the kit car industry and those produced by volume car manufacturers.
The trouble with forums such as this is that certain suppliers have friends who are so constantly posting that it makes the forum far from impartial but so many readers are impressed by the weight of postings that excellent bikes like the Tonaro rarely get considered.
Hope the foregoing is of interest.
KudosDave
Kudoscycles
Apr 15, 2011
5,566
5,048
www.kudoscycles.com
Trex said: 'The Bear's BPM motor is optimized for weight carrying at low speed, the CD is optimized for high speed or high slope.'
GeeBee said: 'The advantage of the crank drive comes at the very steep end of climbing, it will be slower than a high powered hub but will climb a steeper hill with little assist.'
And many other posts that I've read mention that crank drives are better for climbing.
Of course it may well be that a particular hub drive is better than a particular crank drive as it may have more torque or more power, I confess to general ignorance on these matters, which is why I'm asking these questions.
So given two similar bikes with similar power does either system have an advantage in hilly terrain?[/quote
Having ridden pretty much all bikes over the last 6 months the best legal hill climbing bikes are the Oxygen,KTM e-Panasonic and the Kudos Tornado/Typhoon-they are all BPM hub motored. The recent results at the Bristol event would seem to support that.
KudosDave
CameraDealer
63
14
Bolton
As a 6'4" male:
Negative:
Have to put up with sarcastic comments - need thick skin
Difficult to use a stand for maintenance due to bike geometry
Perhaps less control due to swept back bars on more challenging terrain
Pluses:
Easier to get on and off (especially useful in emergency situations)
Less likely to get nicked according to some posters
Encourages relaxed riding which I like.
Overall pleased with my choice of step thru
You make a good point about the stand. I bought one a couple of years ago and find it invaluable when cleaning the bikes or adjusting the gears etc.
I'm going to try my wife's Santana step through on the stand tomorrow and see if I can suspend it somehow as I need to adjust the gears, it won't go into first.
Artstu
2,421
925
The issue the riders had was that when they tried to change to a lower gear, they kept pedalling, but the nexus 8 wouldn't change gear under load, so they ground to a halt in too high a gear. To change gear on the Nexus with the Classic Bosch you have to stop pedalling briefly to allow a gear change, it isn't an issue once you've got the knack, it's certainly a lot easier to get perfect gear changes than the Woosh and first generation Kudos crank drive systems.
It certainly isn't the most powerful system out there, but it is more than enough for me, and I remain very happy with my Bosch bike, and the Nexus 8 is now performing very well after the original was replaced due to a slight fault.
Reactions: Kudoscycles
trex
7,703
2,671
on the Bosch, you stop pedalling and the power stops nearly instantly, on the Woosh, the power decreases for about 2 seconds before stopping due to the PAS sensor programming. The trick with the Woosh is to stop pedalling for 3-4 seconds holding throttle to full, blip the brakes to instantly cut power (I reckon it takes about half a second to cut the throttle), shift down immediately after you blip the brakes. The throttle power is re-instated about half a second to a second from releasing the brakes and moves the chain for you.
Artstu
2,421
925
on the Bosch, you stop pedalling and the power stops nearly instantly, on the Woosh, the power decreases for about 2 seconds before stopping due to the PAS sensor programming. The trick with the Woosh is to stop pedalling for 3-4 seconds holding throttle to full, blip the brakes to instantly cut power (I reckon it takes about half a second to cut the throttle), shift down immediately after you blip the brakes. The throttle power is re-instated about half a second to a second from releasing the brakes.
As Kudos Dave has said before that's completely unacceptable for his customers to have to do. and I most definitely couldn't live with that.
Glad you've found a way around a very poor set-up though.
trex
7,703
2,671
I don't even have a throttle on my bike and I don't have much problem with shifting gears on my BBS01 which has a very similar setup. Ask Tonaro owners, their bike setup is the same as the Woosh CDs.
I think kudosdave makes a mountain out of a mole hill.
Kudoscycles
Apr 15, 2011
5,566
5,048
www.kudoscycles.com
Trex,we are all starting to appreciate that you are the unofficial (or official) marketing agent for Woosh bikes,but I don't think Hatti would appreciate that according to your latest posting you have to disengage power for minimum 6 seconds on the Woosh CD to execute a smooth gear change,on some hills the bike would surely have stopped!!!!!
KudosDave
Kudoscycles
Apr 15, 2011
5,566
5,048
www.kudoscycles.com
Trex,unfortunate choice of words...with gear changes such as this we won't be climbing mountains or mole hills!!!!
KudosDave
Reactions: Artstu
trex
7,703
2,671
dave, Hatti can post for herself, I only give my view on their bikes.
The Woosh does not stop because you have the throttle on full, same as riding on throttle alone without PAS. Try it for yourself, disconnect the PAS - the throttle alone makes the bike responds nearly instantaneously. Other members who use thumb throttle without PAS can confirm this.
I like crank drives - hub motors like the BPM make people fat.
John F
435
55
Let us know how you get on with the stand
John F
435
55
Absolutely. What's all this fuss about! Get to the bottom of the hill, take a look up it, select appropriate low gear then go for it. Instead of worrying about constantly changing gear, sit back and enjoy the view!
I accept that if there is a hidden super hill that's out of site that could be a problem, but if your are in gear 1 or 2 there's nowt you can do about it!
Kudoscycles
Apr 15, 2011
5,566
5,048
www.kudoscycles.com
Trex.....my experience is that throttles are the item that most causes e-bike users to lack exercise,but I appreciate that some riders cannot ride their bikes without the throttle.
With regards to hub motored bikes you have a choice between torque sensor and speed sensor. Torque sensor is best for those who want still to achieve exercise,speed sensor is best for those who want an easy ride,but the controls on both bikes allow you to decide what you want from the bike.
I have a customer who bought one of the Kudos City bikes,between Redbridge 2012 and 2013 he lost 2 stone weight with a hub drive bike.
The broad brush statement ' hub motors like the BPM make people fat' is a bit of an extreme statement,there are literally hundreds of users of KTM Panasonic ,BH Emotion and Kudos Performance bikes who I am sure would not appreciate you calling them fat!!!!!
Jason Scott
92
13
48
Someone send me a couple bikes on trial and as a complete ebike newbie I'll give you a fair and honest review of CD vs BPM! :)
Kudoscycles
Apr 15, 2011
5,566
5,048
www.kudoscycles.com
On almost every electric bike I have ridden,it is very rare to go down to gear 1 or 2,the cadence is so fast on those gears that the effective speed of the bike is so slow that it has fallen off the minimum torque range of the motor,in these gears you could be going up a hill at 2 mph with your feet wizzing round-when the old lady on her Zimmer frame starts overtaking you it may be time to change up!
I ride a Kudos Secret bike a lot,I think only once did I select gear 1 on a short 20 degree slope,it was really too slow for balance and I was pleased to soon change up.
All electric bikes have so much rider plus motor power that it is normally easy to ride in higher gears,at which point the motor power,road speed,cadence and balance all seem to harmonise.
KudosDave
Artstu
2,421
925
I'd go for the Tornado out of those 3 myself. I certainly wouldn't have a CD given the gear change issues.
