The genuine GoPro quick release mounts are robust and reliable, and you can remove camera in just a couple of seconds. Their slide in slot has solid thick sides which will not let you down.
Beware the cheap alternatives which have the vital slot side pieces attached only at the ends, with gaps between. They crack and allow your expensive camera and evidence to go bouncing down the road.
Other laptop boxes are available.
They also have slightly different sticky pads, thinner, different red, different font, perhaps not the full 3 M! Still very sticky.
A trick I learnt from the GoPro surfboard mount is that a security string can be used around the mounting clamp bolt to save the camera if the mount fails.
These larger area adhesive mounts with secondary string mount were on offer when I bought extra batteries this summer, couldn't resist.
