Today on the way home the left crank started to rub against the swing
just what I was afraid of, has just happened. Don't know what happened really, guess the swing flex did swing too much or something. Think I will try to quick fix this by slightly bending the crank arm a little, Z-shaped 5mm or so would do it. Yes I might loose rigidity but it will work
like it should have done from the beginning. Can't believe how bad stock settings was! Luckily I bought the USB cable before I even maidened the bike
but I like riding trails on moderate assist though, feels more bike-like and you are more connected somehow.
So next thing to try is adjusting the PAS-settings. Have not tried so much yet, will give these new settings a while to sink first.
I also need to adjust the throttle. It is quite bad for using as push assist controller. The push assist button is also lousy so I really need to get this throttle working the way I want. Guess if I lower the maximum speed on throttle I get the result, maybe, but that doesn't feel right either.
Thanks all, have now got my bike working good! Just need to ride it now and get used to everything, getting to know each other.
/edit: I replaced the PDF with one that has correct display stock values
Tried with 60% now, didn't get that sensation as when I increased current decay, but it starts to feel a little more "normal" now I thinkAgree with others here , 60 to 80 is the "normal" range for keep current
Yes, I believe that's the way. Just that you get tempted to use the highest setting all the timeYou can control your battery usage better by setting a nice wide range of PAS settings.
