November 11, 201510 yr Anyone got one of these? I can't find the weight of the bike anywhere or much about the Suntour system. Also reports on Halford's website are very positive but I thought the 36v 9ah battery might be a bit weak.
November 11, 201510 yr The battery will be strong enough, but it doesn't have a very big capacity. Depends how far you want to go on one charge.
November 11, 201510 yr Author The battery will be strong enough, but it doesn't have a very big capacity. Depends how far you want to go on one charge. Thanks for your help. Probably doing about10 miles to start but hoping to join my husband on some of his shorter (30 mile) cycles eventually. I had been looking at the Roodog Chic, which has 10ah battery, but the battery is enormous. Their website says Last generation battery. When I asked eBikes direct they said it meant latest, but based on the size I think it is probably an older generation technology. The benefit of the Carrera is that I have a Halfords close by if there are issues. It also look great and the battery fits neatly on the (ladies) crossbar. Doesn't have a throttle or lights and I need to make sure I can fit a pannier rack for shopping.
November 11, 201510 yr Thirty miles from 9ah could be tight - that applies to whatever ebike you buy. Your weight and fitness is important when going for maximum range. You don't need to be Laura Trott, but it will help if you are already active even if it's only in a limited way.
November 11, 201510 yr Author Thirty miles from 9ah could be tight - that applies to whatever ebike you buy. Your weight and fitness is important when going for maximum range. You don't need to be Laura Trott, but it will help if you are already active even if it's only in a limited way. Well I am overweight, but do cycle a bit and walk at least 6 miles a day with the dogs, so not a complete sloth . The Suntour system seems to be well integrated
November 11, 201510 yr Cycling a bit and walking six miles a day makes you a lot fitter than many new ebikers. It means the 9ah battery on the Carrera is far more likely to take you 30 miles, although you will need to use lower assistance levels. The Carrera is new to the market, so I doubt anyone on here has one yet. Ebikes at this price point are much of a muchness, so you are right about the advantages of buying locally. From the pics on the website, it looks like the bike has mounts for a carrier. But don't worry about that, even if there are none, there are always ways and means. Lights are easily sorted, lots of clip on LED rechargeables which are bright and last well - allow up to £50 for a good pair. http://www.halfords.com/cycling/bikes/electric-bikes/carrera-crossfire-e-womens-electric-bike
November 11, 201510 yr Author Cycling a bit and walking six miles a day makes you a lot fitter than many new ebikers. It means the 9ah battery on the Carrera is far more likely to take you 30 miles, although you will need to use lower assistance levels. The Carrera is new to the market, so I doubt anyone on here has one yet. Ebikes at this price point are much of a muchness, so you are right about the advantages of buying locally. From the pics on the website, it looks like the bike has mounts for a carrier. But don't worry about that, even if there are none, there are always ways and means. Lights are easily sorted, lots of clip on LED rechargeables which are bright and last well - allow up to £50 for a good pair. http://www.halfords.com/cycling/bikes/electric-bikes/carrera-crossfire-e-womens-electric-bike Thank you very much for your help. I didn't realise it was new to the market, which explains why there is not much info on it.
November 11, 201510 yr Anyone got one of these? I can't find the weight of the bike anywhere or much about the Suntour system. Also reports on Halford's website are very positive but I thought the 36v 9ah battery might be a bit weak. Very nice looking bike. I would say 20 kg tops for the weight, without rack and mudguards. The Suntour fork is one of the entry level trekking forks with manual lock out.
November 11, 201510 yr I fitted an 8fun kit, with a 9a/h bottle battery to a Carrera Crossfire. Never fitted the pedelec and just use the thumb throttle as & when i need it, which is a lot of the time. I get about 30 miles from the battery, but i notice the power dropping off after about 15/20 miles. It may well be better mileage just using pedelec, i'll have to fit mine one day and see what difference it makes. The Carrera Crossfire's are pretty sturdy bikes and mine takes everything i throw at it and nothing has broken. The Crossfire is 14.5 kilos.... so probably about 21/22 kilos with the kit. The Crossfire E is a nice looking bike and of course you have easy returns and repair with a Halfords being local. If you take out a british cycling membership you get a discount at Halfords, 10 or 15 %, cant remember which, but the discount should be a lot more than the membership cost.
November 11, 201510 yr I fitted an ezee kit to a Carrera crossfire 3. Bike started at 15.5Kg (it had 24 gears) and ended up at 28\Kg after fitting kit, panniers, lock, waterbottle, mudguards, stand and lights. The bike itself feels great, responsive and the quickfire gear change is good. Disc brakes took a some fettling as Halfords hadn't set them right but work well. Don't know the system fitted to the Carrera e, but I would think that 9Ah is a bit small. There's nothing worse than battery anxiety when you're miles from home and thinking of having to pedal a heavy dead lump home against the wind. (Have you noticed how there always seems to be a head wind when cycling?) Overall I'd say the basic bike is nice enough and can be had for £255, so I'd look at that and look at kits with a bigger battery.
November 11, 201510 yr As with the thread 'First Bike' the op was looking at the same bike and had doubts about the 9ah battery, take a look at the similar spec'd Woosh Karoo cheaper and stronger batteries. But depends how tall you are. Sorry Earn re- read your post the Carrera is more suitable for you being a unisex style or as I call it a ladies model, little known about the Suntour hub motor on this forum Flec or Trex may be able to shed more light !!! Edited November 12, 201510 yr by Nealh
November 12, 201510 yr As with the thread 'First Bike' the op was looking at the same bike and had doubts about the 9ah battery, take a look at the similar spec'd Woosh Karoo cheaper and stronger batteries. But depends how tall you are. Sorry Earn re- read your post the Carrera is more suitable for you being a unisex style or as I call it a ladies model, little known about the Suntour hub motor on this forum Flec or Trex may be able to shed more light !!! As kiwi said upthread, Suntour is the forks. It's not clear from web spec what motor the bike has.
November 12, 201510 yr Ah maybe I misinterpreted the bike details the hub looks to be 120mm. It does say the 8 sp Suntour system will help you up the hills which implies its the hub drive as it mentions the forks separately but this can be any Chinese re -branded hub which Cyclotek do using the MXUS. Edited November 12, 201510 yr by Nealh
November 12, 201510 yr I saw this bike recently at Halfords. I started asking some technical questions of the bike department staff and it was a deer in the headlights moment. One went out back and came out with a training advisory pamphlet and handed it to me to read. Not a confidence building exercise I can assure you.
November 12, 201510 yr Ah maybe I misinterpreted the bike details the hub looks to be 120mm. It does say the 8 sp Suntour system will help you up the hills which implies its the hub drive as it mentions the forks separately but this can be any Chinese re -branded hub which Cyclotek do using the MXUS. Ah, the 'detailed specs' for the bike do give the motor and battery as Suntour, so it looks like it is.
November 12, 201510 yr Found it thanks Google http://www.srsuntour-cycling.com/e-bike/ats-rear-motor-system/
November 12, 201510 yr Author The battery and motor are also suntour biuagain not much info on them. Neat bike though as you say Found it thanks Google http://www.srsuntour-cycling.com/e-bike/ats-rear-motor-system/ Thanks everyone. It took me a while to find the detailed spec too, but I think the while hub/motor/controller system is Suntour.
November 13, 201510 yr Author Had a shot of one last night and really liked it. Gearing on flat, with no assist, was much better than anything I have tried.
November 15, 201510 yr Author Ok, I am now the proud owner of a Carrera Crosfire E. Only played on it today but it is so much fun. Turns out although spec'd as 9ah, the battery is in fact 11ah, as it says on sutour web site. So now it is all sorted I can come clean with my story. I had researched e bikes and settled on the Roodog Chic. They had none in stock and I had several very pleasant exchanges with Roodog themselves. I decided to wait until they had some shipped in. I had to buy the bike through Halfords as they run my company cycle to work scheme. The use middleman e bikes direct to source Roodog bikes. I spoke to them a couple of times too. Both Roodog and e bikes direct were very helpful. Eventually after about a month the bike was in stock and I ordered it. It arrived at Halfords with no paperwork so they couldn't contact me. No worries. After a couple of weeks I called to ask if they had it and they said yes. The bike came ready built. I picked it up and was really chuffed as it looked great in white. Took it out for a shot and the chain came off almost immediately. Used the handy throttle to get home assuming it just needed set up properly. On inspection the derailleur plastic housing was broken and the limit stops were damaged. No sign of a knock, scratches etc so assumed it had been a knocked whilst packaged in transit. Annoying but probably fixable. Then went to remove the battery. Nope, the top pannier rack was digging in to the battery and it was impossible to move. This didn't look like damage but like it had been built wrongly in the factory with the battery in situ. Had enough and took it back to Halfords who refunded me and I bought the Carrera. Lucky escape I think, though the guy at Roodog was very nice, but I am afraid I didn't want to have to wait another two weeks and still potentially have issues. I ordered the Carrera on Friday night and picked it up lunchtime today with everything I chose fitted. Great service and I love the bike. Happy ending
November 16, 201510 yr Good to hear Earn, 11ah sound s a bit better it should be a sensible buy keep us informed.
November 16, 201510 yr Strange that Halfords have listed a lesser spec battery !.... I would have thought they would want their Carrera Ebike to appear as best they can. I would check that its just a mistake on the spec listing.... and they haven't asked Suntour for a smaller 9ah battery to keep their costs down for a higher profit margin.
November 16, 201510 yr Author To be honest, I assumed that was the case but the battey that came with the bike clearly says it is 11ah. Cycled 20km this morning with a headwind using Eco assist apart from hills and the battery is still showing full charge. Another thing I really like is the control monitor. It is big enough to see easiky and backlit and has most features you would want from a bicycle computer. Best bit is that the controls for adjusting level of assist etc are on the handlebars right next to your left thumb not on the monitor. Really easy to move up and down without having to look.
November 16, 201510 yr To be honest, I assumed that was the case but the battey that came with the bike clearly says it is 11ah. Cycled 20km this morning with a headwind using Eco assist apart from hills and the battery is still showing full charge. Another thing I really like is the control monitor. It is big enough to see easiky and backlit and has most features you would want from a bicycle computer. Best bit is that the controls for adjusting level of assist etc are on the handlebars right next to your left thumb not on the monitor. Really easy to move up and down without having to look. Well that certainly is a nice bonus to what you were expecting..... makes this bike even more of a good buy i reckon.
November 21, 201510 yr Thanks for your help. Probably doing about10 miles to start but hoping to join my husband on some of his shorter (30 mile) cycles eventually. I had been looking at the Roodog Chic, which has 10ah battery, but the battery is enormous. Their website says Last generation battery. When I asked eBikes direct they said it meant latest, but based on the size I think it is probably an older generation technology. The benefit of the Carrera is that I have a Halfords close by if there are issues. It also look great and the battery fits neatly on the (ladies) crossbar. Doesn't have a throttle or lights and I need to make sure I can fit a pannier rack for shopping. I did 15 miles on (red) mountian trials & the battery still had 3/4 left... Tis an awesome bike
December 4, 201510 yr hello, I own this mens version of the Carrera Crssfilre E-bike since beginning of October. The battery indeed is 11ah. I had problem with mine (please check yours!) that the electric cable which runs from the batter/controller to the electric motor was guided in such way that was trapped between the kickstand and the brake disc. This caused that the cable was 'shaved off' by the rotating brake disc. The cable should be placed on the outside of the kickstand as shown on Halfords photos. The whole rear wheel had to be replaced. Apart of that it is a very good bike. I use it to commute to work 9 miles each way and the battery lasts for 2 days and I still have approx 20% left. One question. I have not got much paperwork with the bike for example there was no user guide related to the operation of the computer. Did you get this? For example I cannot figure out how to re-set the trip counter (distance and total distance). I've tried everything but still cannot set it to '0'. Any ideas? Edited December 4, 201510 yr by wobare
