Thoughts on Carrera Crossfire-E
If an ebike switches itself off and the display on the handlebars goes off, it's almost certainly a problem between the battery and the controller. Try a velcro strap to hold the battery tight against the frame to see if it improves.
Reactions: LeighPing
5,786
Only today I have found out that in order to reset the trip computer one has to press plus and minus together and that is not what the manual is saying.
I have posted the LCD-3 manual in the ressources section. You press them about a minute after switching on then the on off button very briefly to reset.
Mariusz
10
67
Thank you very much for your advice. I will try to follow it immediately.
My feeling is that it is something to do with the battery as it sometimes switches off on bumpy roads.
Mariusz
10
67
Thank you Anotherkiwi.
I must have missed your post. Silly me.
Leccy
137
24
Anyone know if you can get a spare charger for this bike? Looking to have one at home and one at work.
What connector does it have and what are the markings on the charger?
Sent from my Evolution i7 GTX970 PC using Google Chrome
Leccy
137
24
Bike hasn't arrived yet. Will take some pics when it does.
Leccy
137
24
wobare
11
53
Bristol
Mariusz,
It appears that the problem has gone - for now at least. I did nothing but for at least last 3 months I did not have any unexpected failures. Although I have noticed that sometimes the battery indicator goes from 99% (this is the maximum) to say 85% within first few hundreds yards....and then the reading stays like that for several miles. So I believe there is something with the batter voltage. I managed to nearly completely discharge the battery and charge it again twice - maybe this helped to stop the unexpected switch off?
wobare
11
53
Bristol
Mine never switches on bumpy roads. Most often it happened when I stopped say at the traffic lights for example. When I tried to start pedaling again the screen suddenly went blank. Only pressing the power button on the batter could bring the bike to life. Last couple of times when it happened I had to press it 2 - 3 times as after a short period of being 'on' the bike was switching itself off again. Only after second or third attempt the 'fix' was permanent. As I said in other post for last 3 months no problems with it. I will see what will happen when the temperatures will be higher. Maybe it is an temperature problem?
It's possible that it has a sleep mode. If the wheel doesn't turn for a set amount of time, it switches off. Sleep mode time is normally adjustable, but you need the software manual.
Leccy
137
24
The charger has arrived. Pic attached.
Leccy
137
24
Another pic
dazbobaby
10
54
halifax
Hi, any of you, owners of Carrera Crossfire E-bike get this problem that the electrical support switches itself off randomly?
Yes but I only noticed this when I went down a VERY bumpy cobbled road and only twice in 200 miles has it done this.
dazbobaby
10
54
halifax
mcozzy
32
24
54
Anyone know how to change the wheelsize on the controller? I'm guessing decreasing the wheelsize the bike thinks it has will allow more assisted speed..
A snippet of info from the 2011 manual, which has been removed in subsequent manuals, although this is the older model of controller & doesnt work for the 2015 model.
1. Switch to “average speed”
2. Press the “Mode” and the “Info” button simultaniously(FAST)
3. The currently set wheel size will show up
4. To change to a different wheel size press the “Mode” and “Info” button again 5. After the wheel size starts blinking press the “Mode Button to change to a different size 6. Press the “Info” button twice to store your changes.
ebike101
9
9
Hi mcozzy. I think that you can view the wheelsize by pressing + & i together for about 5 seconds but I'm not sure how you can change the setting. Perhaps you'll have more luck than me!
Reactions: mcozzy
