ebike101 thanks for the manual. It helped me understand a few things. For example why the background lighting of the display is sometimes brighter and sometimes dimmer
I can say that I could not re-set the trip distance by pressing the combinations as per manual. I did exactly what you did (-&+) and it worked. So I guess there must be something with the different software.
I am not sure whether it is possible to change the display to mph. In the manual they only mention kmh.
I too have feeling that it would be better if the power cut off at 30kph although I have to say that mine cuts at 27.5 kph (according to bike's speedometer).
The manual states that the battery should be discharged every 3 months, would be good to have it done by the charger. I tried to discharge the battery once by continous cycling aroud the house and it is a pain beacuse once the battery is 5% or less the power is reduced so it takes ages (i got as low as 1% and gave up).
I am surprised that the manual does not mention that pressing the button on the battery may show ifo such as capacity of the battery, how many time it was charged etc, I read about this in the manual for 2014 model available on the Suntour but it works also on this battery.
There is a mystery drawing in the manual on page 9 showing battery indicator with one light on and one flashing (0.5s ON/0.5s OFF) - any idea whai is this for?
Generally I am happy with this bike particularly beacuse it has got a good range on one charge and beacuse it appears to be asimple bike. Hopefully it will be reliable (I only did just over 200 miles on it).
