Cut out the rubber with a Stanley knife and the screw threads will be there. Hopefully! Mine were.right got the shoes today but there are no holes as it is covered with rubber?
do i have to remove this or got the wrong ones ?
I never have and never lost one but it can't harm.do you use locktight on the shoe bolts ?
no such thing as a five minute job
Tidy, my post was what was in my saved list, as is what I needed.nice try but the wrong size isis m15 8mm
https://www.tredz.co.uk/.FSA-Self-Extracting-Crank-Bolts-ISIS-M15-Steel_106205.htm
the bottom bracket is the motor i have changed the crank arms and peddlesBeen meaning to ask you..why did you change your bottom bracket?...think you did anyway..it was some time ago.
Have them on the Giant Glory, they work well. Just a blow out with degreaser when they are off and re-lube then good to gosaves using a crank puller at the end of the day so easy to clean the drive side![]()
