Brakes sensors disconnect them and try motor, if possible try the pas option I suggested for testing before throttle at the end of #57.
Done, all connectors are fine but still no movement.The wire short is only 2 pin so usually for eabs of cruise control.
Double check your hall connector and make sure all pins are inserted nicely and none are backing out, and are colour to colour.
Yeah that's correct , the three main wires to the wheel were connected and I had all the wires on the hall sensor controller side connected and then put the battery on but I'm 90% sure i had not shorted the LED at this point because it wasn't mentioned till #30 and I had no idea, so there was no power in the wires I shorted.http://www.ebikes.ca/documents/HallSensorTestingFinal.pdf
In #10 you said I mistakenly connected 1234 together and powered up this would have caused controller damage but not motor damage as the motor halls weren't connected.
Morning, I've been having a think and I wanted to run it past you.http://www.ebikes.ca/documents/HallSensorTestingFinal.pdf
I have continuity on the wire from controller to wheel. I also checked the three power pins on the wheel side of the wire and they had continuity with each other, does that suggest a short in the wheel somewhere?The controller wire/cable to the hub is easy to check with a continuity check on each wire/pin out and will give a definite buzz.
The led receives power via the controller and then sends signal back, you should see 54.6v at the controllers +/- wires with all connected up.
See previous post, I was editing it as you were postingBeing a new motor there shouldn't be an issue as they don't usually cause issues unless abused.
We know it can run sensored or not so only the 3 phase wires can be of issue and unless there is damage where it enters the axle issues are unlikely.
Does the hub/motor turn on the axle ok.
Hoorah we are getting somewhere. Held the 6 kph down and the wheel spins. So what does this mean and what do I need to do to rectify it and thanks for your helpOne more thing you could try. There is a possibility that your controller is configured to meet the EU standards so that the throttle will only work when the pas is engaged. If your 810 display has a 6kph ‘walk’ button, with the motor reconnected and power switched on, try holding this down and see if the motor turns. If the motor moves with this, but not the throttle, it’s most likely a controller configuration or throttle problem. If it doesn’t work you’re back where you started as this button may not be configured either.
Nice one, I hadn't thought of that as my controllers are usually from PSWP and not needing parameters changing.One more thing you could try. There is a possibility that your controller is configured to meet the EU standards so that the throttle will only work when the pas is engaged. If your 810 display has a 6kph ‘walk’ button, with the motor reconnected and power switched on, try holding this down and see if the motor turns. If the motor moves with this, but not the throttle, it’s most likely a controller configuration or throttle problem. If it doesn’t work you’re back where you started as this button may not be configured either.
It means full throttle is only available once pas is activated and is configured so. To confirm this you need to manually get pas working first and only when pas is working try the throttle for full power.Hoorah we are getting somewhere. Held the 6 kph down and the wheel spins. So what does this mean and what do I need to do to rectify it and thanks for your help
So how would I go about that, I don't have pedals as it's electric power only.It means full throttle is only available once pas is activated and is configured so. To confirm this you need to manually get pas working first and only when pas is working try the throttle for full power.
Oh no, so the controller I have is not compatable , so I need to buy another type, bit of a gutter after just spending £50 on it but on the bright side at least I now know my battery and motor are fine.I think the bad news is it may not be able to change the settings of the KU95 to operate on full throttle alone.
So if I ordered from aliexpress would that controller come with the same connections . Also when you say the SOxx series are you meaning any controller that starts with SO , sorry if I'm asking stupid questions, I just want to be sure i get it right this time.If the KT KU95 setting can't be changed to full throttle, then a KT dual voltage controller and lcd will work 100% as settings are user friendly and changeable.
The pair are about £57 inc p&p.
Sell the KU95 & lcd on here or ebay.
https://www.aliexpress.com/store/product/36V-48V-500W-Brushless-DC-Sine-Wave-sensor-Controller-ebike-Electric-Bicycle-Hub-Motor-Controller-with/1314442_32759790640.html?spm=2114.12010612.8148356.4.42c7382f9y2Htf
https://www.aliexpress.com/item/ebike-24V-36V-48V-intelligent-LCD-Control-Panel-LCD-Display-Electric-Bicycle-bike-Parts-for-KT/32613010219.html?spm=2114.search0104.3.267.621863d4BwD7IS&ws_ab_test=searchweb0_0,searchweb201602_1_10152_10065_10151_10344_10068_10130_10324_10342_10547_10325_10343_10340_5722611_10548_10341_10696_5722911_10192_10190_5722811_10084_5722711_10083_10618_10307_10820_10301_10821_10303_10059_306_100031_10103_10624_10623_10622_10621_10620_5722511,searchweb201603_43,ppcSwitch_4&algo_expid=3c98178e-c280-45c8-a37a-e243e7034211-40&algo_pvid=3c98178e-c280-45c8-a37a-e243e7034211&priceBeautifyAB=0
Alternately S0xx series and lcd3 from bmsb.
