No use jumping at buying more items until we get to the bottom of exactly what you have done or may have damaged !!! More haste less speed.
Pic doesn't help need a clear pic of controller disconnected and the wiring .
The kit you bought looks like the non led one with the three speed switch/throttle combo unit. I believe you may have shorted the 5 motor/ hall wires up in error if so then motor halls may also be smoked as the only 5 wire connector I can make out is the motor hall connector.
A pic of the disconnected controller please.
