Neptune yes that is the power lead but its coming "from" the controller to the battery so no voltage on it to measure until after you connect it up!
Some controllers do have a polarity safety for connecting up the wrong way round, but not an ideal way to test it. As I said hard to determine without plugging it in. I was fairly confident that the centre was positive though. Interesting about the throttle but most of that went over my head lol
The countersinks don't really need drilling out any more in fact the opposite if you want all the spoke heads facing out then the larger countersinks need to be reversed on the outside of the flange i.e. all smaller counter sinks on the outside of the flange and larger ones on the inside.
Alan (catsnapper) was helpfull as always and suggested another viable way forward would be to put spoke head washers in the larger countersunk holes on the outside.
This then would probably mean though that the inside holes would have to be enlarged to free up the spoke curve wich as you say has the potential to further weaken the flange
Going to spoke heads in/out to keep it radial seems the best compromise. Of course when crossing spokes the holes are suitably drilled.
At least I have learnt that the larger countersink is for the spoke curve not the head
Having said that I checked one of my existing Brompton wheels and I have indeed put spoke heads in the larger countersunk holes and you can see daylight on some of them. But then again its over two years old with 3500 miles on it, so it can't have been that bigger of a mistake.
Whilst some care obviously needs to be taken when building wheels, I think is not an exact science (or maybe it is) and in this application we often can get away with it more than perhaps a high performance, lightweight, racing machine.
Regards
Jerry
