Quick update.
I now have 150 miles on the bike - 7 commutes and a few "play" outings.
I have adapted the brake switch to my rear brake lever and expoxied it in place (will post photos later) - not connected up to the controller yet - I'll do a few miles on the road to ensure the epoxy is strong enough and the switch isn't going anywhere. I need to extend the cruise control wires next.
I've neatened up the battery pack wiring a bit and now taped the pack together (again photos coming).
The Turnigy 200w charger is not so good after running a storage mode on the pack - the charger got very hot and now it wont charge at more than 3amps :-( Not bad though - I'll keep it in the garage and use it to charge my 18650 cells I use for my flashlight hobby and the nicad/nimh packs I use for my R/C car. To replace it I now have a lovely iCharger 106b+ - awesome bit of kit and smaller than the turnigy even though it's more powerful at 250watts. I also love the geekiness of logging the charging to my laptop
I also have a Meanwell S-350-48 power supply on it's way from China so I can bulk charge the pack without splitting it - aim is to bulk charge on the bike to 49.8v then balance charge every 10 charges.
As far as range goes - I used full throttle all the way last week on my commute (19.5miles round trip), into a 20 mph head wind, with minimum pedalling and I put 15566mah back into the pack - that's 78% of the capacity of the pack- perfect
I have also bought a celllog 8m to keep an eye on the balance and on Sat I had a Turnigy Watt Meter delivered. Popped it on the bike last night for a quick run and I know why the bike feels so powerful - max amp draw was 16amps - that's 728watts peak! I tried to reprogram the controller to 12amps but the settings don't seem to take - I'll have a look at that later. Let's see how long the Tongxin lasts at 728 watts! (I'm not really bothered if it blows, I'd quite like to experiement with other motors
. Cruising along at 20mph pulls about 8amps but 16mph only pulls 4 amps- you can really see the logrithmic effect of speed on power draw.
OK, so that's it for now - photos to follow soon.
