Just for a laugh...
Gubbins
Wonder how the Ultrasonic bath would compare with a standard chain cleaner bath with an electric air pump hose down in the fluid? Probably too many bubbles! o_O
The ultrasonic has to be the easiest thing ever... put the cleaning fluid in, put your chain in,turn it on and in 3 minutes it's done.
C
Cyclezee
I have an ultrasonic cleaning bath with built in heater left over from my previous profession.
It has it uses and limitations when it comes to cleaning, degreasing, descaling, etc. Using the correct fluid for each task is important.
A word of caution though, never put any part of your anatomy in the bath whilst it is operating and don't use them with flammable liquids.
The ultrasonic waves can be harmfull to human tissue, they also increase the evaporation rate of solvents and flammable liquids which could lead fire or worse.
VictoryV
310
208
78
near Biggleswade
Phil, careful how you use the paraffin.
VictoryV, just out of interest, does the name N Clutton mean anything to you? There is a reason for asking.
Sadly no. However, If I have caused offence, or evoked sad memories with my account, I apologise. What I recounted happened a long time ago.
Gubbins
I sort of guessed it might be a hazard to put paraffin in there, but so far no problems....
neptune
1,743
353
Boston lincs
I find that if I use paraffin in my ultrasonic cleaner, my dentures taste awful next time I put them in there. On a more serious note, reference was made to paraffin wax, AKA candle wax. If the zips on your panniers or clothing become hard to use, rub the zip with a candle. It is a brilliant zip restorer.
VictoryV
310
208
78
near Biggleswade
Candle wax is also brilliant rubbed on sticking drawers or doors or windows to free them up. I also used it on fence panels when sliding them into the concrete fence post groove.
Reactions: neptune
VictoryV
310
208
78
near Biggleswade
Also do not use near dogs, industrial ultrasonic cleaners have a major imact on their hearing it must be like a continuous gunshot or screaming noise at an incredible decible level
john h
510
147
murthly castle estate
Eddiepg a site you would like, zen the art of the alcohol stove,
VictoryV for many years i used nothing but paraffin wax as a lube on my bike chain and gears, i would clean the chain in a tin with paraffin,take it out to dry,then heat up wax in an empty bean can dip the chain in it and put the rest on the rear gear cluster while turning it round, never had the dreaded black oil line on the trousers hems, chains+gears run for years fine
VictoryV
310
208
78
near Biggleswade
Eddie, thank you for your conversation query. I have tried to reply but Russ's mailbox is full so here is tthe text I have been trying to send you
Eddie,
Yes I did mention a Vulcan, but that was at the end of my Apprentice Training at Halton in 1966 (105 Entry). I then went to Cranwell as a Cadet "Electrical Engineer" (95 Entry). After graduating 5 years later, I seemed to get specialised in communications working on HF radio, the founding stages of Military Satellite Comms (the real SKYNET) for the RAF and NATO. Did a spell as an Officer instructor at Cranwell and then did my only tour on Aircraft as an engineer on the Jaguar Conversion Unit at Lossiemouth in the late 70's. I then moved into the installation of secure voice & telegraph all over the world. Did 4 years in MOD on Comms systems requirements for defence, finished off with 4 years of military logistics IT. Got a job with IBM based on my miltary comms/logistics skills and finally retired in 2008.
So I never saw a Vulcan in action, and never met your friend, but thanks for asking. I was worried I might have been relating the sad story of a relative of yours
keep pedalling
Vic "
neptune
1,743
353
Boston lincs
I wonder why allotment associations buy paraffin in bulk. I know the official reason is to heat their greenhouses. But I also suspect that they have a paraffin stove in those little sheds you see. A place to get away from the wife, play cards, drink home brew, smoke, vape, swear and possibly engage in satanic rituals.Its a man thing. John h. Like your wax chain lube idea, I might give that a go.
Reactions: Nealh
8,533
Try your local independant diy outlet, mine sells it for a £4.99 in 4ltr can.
neptune
1,743
353
Boston lincs
Our local garage had a sign reading "Two Stroke" and underneath that it said "Toilets". One day my wife asked me, "What are two stroke toilets?"
Reactions: Gubbins
oriteroom
297
110
Castrol R. Now there's a great smell. Never minded a bit of oil seeping past the piston rings and burning on my Norton 600S (four stroker) so I could just enjoy that smell.
wurly
501
9
Yeovil, Somerset
Lots of 'oilers' talk here. How about domestic central heating oil for cleaning/degreasing. I have found it pretty good. Nice and cheap if you can scrounge some off a neighbour :0)
Best wear gloves though and don't breathe it in too much
