How many people are using there e-bike off-road?
6,693
i tried that 1st but from reading i think mine has a hose that lets in air bubbles over time so it might be this as mine 2014 reverb its sorted on newer 1s.
its got air in the hose and or its low on psi got the kit just need some fluid to bleed it :)
Steve UKLSRA
318
293
Porthmadog
www.ukbusas.org
You'll find that even the latest 2016 Reverb seatpost suffer badly from leaks and you'll be bleeding them constantly...just check MTB, etc forums...I run Thomsons on most of my decent bikes and don't have problems as they're
Nitrogen filled and have a great no quibble service backup.
Reactions: soundwave
6,693
there 300 quid tho :(
Reactions: Steve UKLSRA
6,693
edd does ur remote clamp on to the brake lever? as mine is 1 unit brake remote and gear shifters.
EddiePJ
4,632
4,013
Crowborough, East Sussex
www.facebook.com
After researching what others had done, I went for a right hand remote, and turned it upside down, fitting it to the left. It feels really natural mounted like that. :)
I still need to shorten the hose, and really I shouldn't have even been outside playing at all this evening. Paper work or bike! The bike won. :) I'm probably out for a ride tomorrow evening, so won't get a chance to carry on servicing the bike for a couple more days.
6,693
bloke in the bike shop took 1 look at that and went hummmm no idea lol
also as its in bits why not go 11 speed ?
EddiePJ
4,632
4,013
www.facebook.com
My set up works just fine for my use, but having said that, I've not really used the 42T as much as I thought that would. It will come into it's own in July though, with the next Swiss trip. :)
I meant to add this one yesterday.
Paperwork beckons tonight, so no playing this evening. I would have also liked to have sneaked out for a muddy ride on 1964, but as I'm booked up to go out riding tomorrow night, I had best knuckle down and get some work done. I bet it will rain tomorrow now!
6,693
its for ultra low psi in the tyres for more grip, bit out side my price range tho:(
6,693
got my shock pump and fluid cost 30 quid :( i take it the button under the gauge is to release the air.
6,693
never thought about it till i needed 1 tbh still need a decent pump as well and a few other bits.
a year ago my tool kit was 1 screw driver and a hammer lol
Reactions: EddiePJ
6,693
you thought about putting a ctd remote for the forks and rear sus?
EddiePJ
4,632
4,013
www.facebook.com
You are doing well then. At least you can now check and put some air in your forks. :)
My bike already has a front ctd remote from new, and oddly I was outside fiddling around with it earlier today. I've never found the need to touch it, and it had seized up.
6,693
well looks like i can do the front no problem but rear is just not worth it as can only be done by fox at the factory.
needs a new top piece so that and the 111 quid service will be over 200 quid :(
EddiePJ
4,632
4,013
www.facebook.com
also my rear sus sounds like a mouse, edd do you service yours?
Glad that you sorted it. :)
I hadn't really realised just how worn that my suspension linkages were until this afternoon, when I removed the rear shock. The talcum powder fine sandy soil here when mixed with water, makes possibly the best grinding paste ever. To top it all, it also highly corrosive.
Along with a new rear mech hanger to have as a spare, I've just ordered a new bush kit.
The headset bearings are also shot, which I already knew, but had been putting off replacing until doing this full strip down. This will be my second set.
Again, caused by the aggressive conditions here.
So the service list of parts so far include.
  • Front and rear brake pads.
  • New front sprocket, the cassette is pretty much new.
  • New jockey wheels.
  • New chain, now that makes a change!
  • Brake fluids changed.
  • New headset bearings.
  • new rear suspension bush kit.
Time will tell what the front forks are like when I remove them to check. The wheel bearings are spot on, which really does puzzle me, but I'm not moaning about that one.
Whilst the bike is pulled down, I'm actually quite tempted to have the whole frame re painted orange, but sadly funds won't stretch to that at the moment.
I'm also going to revert back to a clipless pedal set up. Riding the Ultra 1964 this week, has reminded me of how much that I like and miss them. After all of these months of using flats, I still hate the things.
Speaking of the Ultra, I had my first chain snap this week. It had to happen during a night ride, miles from anywhere, in the coldest spot possible at the bottom of a valley that had a stream bed, and the bike had to be caked in mud. I put it down to my own fault though, of not planning ahead and making correct gear selection for the climb out of the valley bottom. An e-mtb makes you very complacent and lazy in that respect.
Reactions: SRS and soundwave
