How long should my ebike chain last?
John F
435
55
Thanks to everyones help.
Update on my "worn?" chain saga.
1) No tight links
2) Measured accurately with steel rule 40 links = 508mm. Actual length 511mm therefore due for replacement
3) Investigated gear change to check for less than perfect set up (seemed ok so far) I couldn't get it into bottom despite accurate adjusting both the limiters. Checked the cable and one strand had strung out, despite my soldering the end.
4) Conclusion is worn chain and defective cable
It never rains but it pours!
shemozzle999
2,826
686
Get your dealer to try an inquiry via their UK website or find a LBS who sells YBN chains and they can source one for you.
http://ybnchain.co.uk/
Although you might find the cost prohibitive looking at their prices for specialist chains.
30,840
Our *.co.uk site only has the normal chains, it seems only the US *.com site lists the e-bike versions like the S8e.
Emo Rider
659
414
I have just replaced the original chain on my BH City 700. In spite of religious care (and no off roading) it was just at the limit on my chain checker. I took eddiejp's advice and replaced it before I needed a cassette too. I had just under 3,000 miles on it. If I was a fair weather rider it probably would have lasted longer. However, using it as a daily commuter, the constant road slime works to defeat even the best of chain maintenance.
El Champiero
119
30
Bristol
In my experience, road slime certainly seems to be more destructive to chains than mud stuck to it from going off road. Not entirely sure why - there are a lot of variables in play though. I think the most important variable here is how often you use the bike. Frequent use (i.e. daily commuting, 5 days a week) is most likely going to wear out the chain quicker than a half-day off road ride in the mud.
D C
1,142
577
Another massive cause of excessive chain wear with derailleur gears, particularly on 24 speed or more, is having the chain on the largest front chain ring and at the same time on the largest sprocket at the rear wheel, likewise the smallest front chain ring and smallest rear sprocket. This is best avoided as the chain will be severely out of line.
It's good practice to use only the the centre front chain ring for the full range of rear gears and when using the outer and inner front rings try not to go much past the centre gears at the rear.
shemozzle999
2,826
686
Dare I say that this is a typical example of where a forum representative could approach the company for sample chains for review and John F could review the product on a long term test:rolleyes:
mike killay
3,012
1,629
I have often wondered whether to try and reduce my thin 8 speed to an old fashioned 4 speed derailleur.
Back in the 1950's, people didn't change their chains ever.
D C
1,142
577
In my case it was because I couldn't afford to!
all my bikes in that era where made from bits of other bikes and as I knew no better they were wonderful.:)
30,840
That's a nice find, I hope someone imports them to the UK.
Since they mention use with the Panasonic units, they should also be long enough for the longer wheelbase for a change.
Emo Rider
659
414
Yes a longer chain for the Panasonic would be great for my BH City 700. I had to use an extra section of chain and a quick link when I replaced it. As a footnote, the old worn out chain was costing me about 5 miles of range. I'm getting my original range again. The bike was new in June and has done just under 3,000 miles. I thought it was the battery.
John F
435
55
How did you figure out the decreased range? A longer chain for my bike too 130 links. Most seem to be 115 ish
Emo Rider
659
414
The indication that my range was better, with the new chain, was immediate. The performance of bike told the story when the power levels stayed in their zones much longer before dropping. With the worn chain, I was getting three round trips in and the battery would sometimes go flat a mile or two before I got home. Now, I am pretty sure I could make an extra one way trip with remaining power like I use to. Two charges later the battery has gone straight to two lights when put on the charger instead of one light after three round trips.
The rollers on the chain were worn and probably full of road slime grit. Where this is a chain drive bike and not a hub motor, it would stand to reason that a worn chain would create more drag on the motor.
