This is what I got from tests on 500W CST :
Wheel factor used 2124 (700 x 25C) gives 26.1mph on normal and 2073 (650A) gives 25.5mph
Poked in the pins of the 3-speed switch and tried it ... the coulors don't match up though - there are 2 blacks and 2 blues on both the controller socket and attached to the switch pins, and then the red wire on the switch is only left with a green on the controller socket to pair to
.. paired connection at the bottom of the pic here :
Connecting up this way gave about 1mph difference with no load speed readings between 25.7 and 26.3mph but no significant variances.
"Originally Posted by d8veh
You could try what I suggested above in case the switch wiring is faulty. Use a piece of wire to join the middle to each of the two sides in turn to see if it has any effect."
Test done and here are the results :
Wire poked into holes with black (middle) and blue wires coming from connector - 21.5mph
Wire poked into holes with black (middle) and green wires coming from connector - 26.7mph
Re-test with 3-spd connector not used - 25.5mph
Re-test with speed limiter connected - 20.1mph
