Has anyone heard of or tried Toseven mid drive?
oztrikes
22
-22
the air gap we have problem with in the TSDZ2 is between the motor and the system housing.
In most crank drive motors, the motor housing has cooling fins and is in direct contact with the outside air for better cooling.
It's not the case with the TSDZ2 and your DM02 which are housed inside the system housing. The improvement we are calling for is to add a thermal bridge between the motor and the system housing or alternatively, replace the system housing to expose the motor housing.
oh dear....this is a bit embarrassing :p:p:p:p:p:p
whos going to tell him?
6,733
give me one to test and ill get a controller 50A
or
if it does not explode its not going fast enough :p
spin to win 1000mph :p
Reactions: lenny and guerney
4,217
Please can you tell me if this Subaru ebike is worth buying?
Standard cheapo Chinese bike with terrible v-brakes, front motor and Subaru written on it. You could buy one for around £800 and put your own Suburu or even Rolls Royce stickers on it. that's half the cost.
This one would be better quality with disk brakes and rear motor- KT controller too.
6,733
oil cooled as non conductive you add a rad and a pump and there you go :p
Reactions: Woosh and guerney
3,410
Thank you @saneagle, your knowledge about ebikes really is quite encyclopedic! And always a pleasure to read.
17,433
care to elaborate for all the members here and give your expert opinion on the quality of materials used and the finishing?
I am not an expert but here is your competition, circa 5 years ago:
Note how short the rotor shaft is?
The rotor shaft gets a lot of stress, you want it as short as possible and the ball bearings on at both ends as big as possible to spread the stress and wear.
the winding:
They use flat wire, machine wound.
The permanent magnets:
they form a perfect circle.
Yours: the motor shaft is too long, the coils are wound by hand, the magnets don't look straight.
17,433
I know what that is....i know what people do with it with strips of metal on a tongsheng.
Can you explain where you intend to put it in the 02?
Your DM01 is better targeted. You should make a 250W version of it.
Your DM02 repeats the same mistakes found in the TSDZ2, so adding fins, a fan or thermal compound will help but they are wasted opportunities.
Reactions: lenny
alexfnoble
68
Im not sure if you are trying to pretend you did notice now but from what you wrote before its clear you hadn't
Where is that compound going to go?
alexfnoble
68
the winding:
This is a render you know?
Blacklite
33
the winding:
So that’s a DIY install motor? Must be if it’s the competition.
Oh hang on… it’s not.
Have you actually opened up a TDSZ2? Given you claimed it didn't have a cadence sensor and also your demonstrated complete lack of understanding around BLDC motor control, I wouldn’t be taking your comments too seriously.
3,410
Why haven't you bought a Toseven motor yet?
17,433
I bought a 36V TSDZ2 about 5 years ago for testing. I opened it once, when it was brand new to take a look. I liked it, so I imported it directly from Tongsheng but asked them for their 48V 250W version.
As it was a brand new motor, I wasn't fault finding and did not notice the PAS sensor on the controller.
It was a mistake which I acknowledged straightaway as soon as you pointed that out.
How much more do I have to grovel for your forgiveness?
How about your expert opinion on things to improve on the TSDZ2?
3,410
It can't be long before someone uploads photos of a complete diassembly.
Let's hope the rest isn't short-lived trash.
6,733
its 2.21 board and off for a ride i even have a dump to go faster :p
Reactions: guerney
17,433
Is this going to be a size competition?
If it is, then you have already won.
I have never been attracted by the OSF firmware because Tongsheng replace any faulty parts under guarantee. So when you told me where the code for the PAS is, I followed up your link and start reading it on my phone while waiting at my doctors surgery. That was the first time I looked at emmebrusa's code. Later, another member posted a link to the field weakening code specifically. I read it looking for a solution to his problem with the TSDZ2, that is at constant cadence, the torque is reduced with battery voltage.
It's not a new issue but none of my other customers mentioned it to me.
I made a suggestion how to amend the code to vary the field weakening angle to compensate for voltage drop.
Does it merit your sarcasm in telling me that I demonstrated complete lack of understanding? Would you like to post your code here to address his issue?
Blacklite
33
Hopefully will have one soon.
Not quite sure how that is relevant to my comment though. Seems as though
I made a mistake with the PAS sensor on the TSDZ2 which I acknowledged straightaway.
As it was a brand new motor, I did not notice the PAS sensor on the controller.
It’s not about grovelling for forgiveness. There were multiple points that you were completely wrong about, and most pointed towards someone with barely any understanding of how modern BLDC motor control works. From a crank sensor being used for motor advance angle, to the TDSZ2 torque sensor being a coil (hint: it’s actually a hall sensor). So it’s worth mentioning to all that your critique is not based on someone with solid engineering knowledge in this field.
For things to improve this would be my top four -
Heat management between stator and case
A proper FOC controller.
Less play in the axle / better and smoother bearings.
A more consistent torque sensor that doesn’t have wildly variable values between units.
Notice how a lot of these are things that To7 have claimed to have addressed.
I personally can’t wait to use one and see if they have.
