Gone for the Bighit
banbury frank
Banned
Jan 13, 2011
1,565
IEC plugs on batterys
Hi
IEC plugs on electric bikes are ILLEGAL Except the input on the mains side off the charger
under the low voltage directive under 50 Volts DC
We stopped using these 3 years ago after reading this article
100, 000 bikes to be recalled in Europe see links below from 2009
Attention: IEC Plug
Bike Europe - News: Flood in e-Bikes Recalls Expected
The other reason is they are Cheap and nasty and not made for the job we use these
Single Modular Connectors - Torberry Connectors Online Shop
The frame off the bike can become live 230 volts mains if plugged directly in to the mains in error Then you or you loved ones could DIE or just burn you house down
If you have this problem This is a job for trading standards they have the power to enforce a recall
This is so important i will start another thread
Frank
Fordulike
3,802
1,538
The solution would be to use a little bit of super glue to permanently glue the mains lead plug into the charger socket.
Then it would be just the same as a charger with a permanently attached mains lead.
" simples " :)
banbury frank
Banned
Jan 13, 2011
1,565
Hi
If you read my posting it says the mains input to the charger is OK it is 230 volts mains that is what the IEC connector is made for
NOT for Battery Connections Out off the charger or connecting the battery to the bike controller
Frank
shep
84
34
You would have to be way beyond stupid to do this. More EU Political correctness nonsense, no wonder they are in such a financial mess. My Tonaro has the kettle plug, i like it, and guess what? it is staying on the bike.
Also what is this nonsense regarding ZOOM forks? i also have a brand new Kalkhoff Agattu C8 which is the more expensive version at 1795 pounds, fitted with super doopah RST forks and guess what? i cannot tell the difference !!!
Fordulike
3,802
1,538
Hi
Frank
Ok, glue both the leads that are supplied with the charger to the charger.
Write a note on the charger 'ONLY TO BE USED FOR CHARGING BIKE BATTERY'
Wrap the charger in fire-proof, non explosive military grade kevlar shielding.
A few post it notes on the fridge to remind you about the dangers of plugging your kettle lead directly into the battery.
Direct hotline phone connection to the local fire brigade, just in case.
If all goes well, then armageddon wont happen
scaremongary will drive potential electric bike users away :rolleyes:
Double "simples" :p
dimmer
30
surrey
I was looking at the manufactures site the other day,products, and they have a model to suit most people,i am interested in the Eagle model which phil says will be in stock in july.
You made the right choice PJM your new bike will be great.
30,660
I think that being unfair to the great majority of the population who are non-technical, including large numbers of members in here.
Why would it be stupid? That IEC plug is a recognised mains connector used on kettles, computers and a host of other common items always for mains connection. An electric bike is nothing like as commonplace an item as those other universally used things, so how would a non-technical person know it was different? As I observed above, some e-bikes have been made with charger included and are plugged directly into the mains. People often buy second hand without manuals and in some cases buy e-bikes with the charger missing, so they would be particularly vulnerable to making a lethal mistake.
After all, it's not unusual to plug commonplace rechargeable items direct into the mains for recharging, electric razors, torches, emergency power supplies and some hair trimmers for example.
It is a good connector as you imply, but made all the better for low voltage use if the version with a 90 degree rotated earth pin/socket is used as some companies do, Wisper for example.
shep
84
34
Flecc
The charger is a sealed unit for this bike, and the output is the kettle plug. I don't know if it just me, but when i want to charge the bike battery, i simply either plug it in directly to its charger, or take the battery off and again plug it into its charger IT IS THAT SIMPLE.
I just get fed up with these EU idiots, and there ridiculous never ending stupid laws. Before long you will need training in how to breathe, or a diploma for taking a wee !!!!. I notice that China fit these kettle plugs, i guess there people are not so spoon fed and actually apply a bit of common sense, probably why economically they are vastly more successfully than us recently, they stand on there own two feet.
And the other thing Flecc is that you have now been downgraded, to a simple "member" you are no longer a Guru, this is a far more worrying development than the kettle debate.
NRG
2,592
10
We are all 'members' now this happened a week or two ago after a bit of a fall out among some forum members...
30,660
Flecc
I agree, it is simple when you know Shep, but as I pointed out, what happens if someone non-technical buys one second hand without the charger as so often happens? I'm also opposed to an excess of regulation, but I think mains safety measures are important for the non-technical, especially with our 220 volts.
Doesn't worry me at all, in fact it pleases me. I never asked for a title in the first place, have refused an offer of admin rights and always insisted that I'm just an ordinary member. This world has far too many titles and uniforms and for me just being ordinary is cool. :cool:
Fordulike
3,802
1,538
In the red corner, the undisputed master of the pedelec community, we have Flecc....
And in the blue corner, a master in his own rights, we have shep.....
Let's get ready to R..U..M..B..L..E..
shep
84
34
I throw in the towel immediately. It was primarily Fleccs superb review of the Kalkhoff Agattu that was the defining factor in me purchasing 2 of them. Listen to Flecc and you will not go far wrong, i still have a lot to learn
eTim
607
Andover, Hants.
I'm not a master of anything or anyone, but neither is anyone my master, nor ever has been.
Best to be a Jack of all than a Master of none :)
indalo
Banned
Sep 13, 2009
1,380
Herts & Spain
Now that we no longer have slavery or serfdom, it's only dogs who have masters as far as I know. Cats, of course, have servants!
A Master's degree in engineering is a nice thing to have though.
Indalo
30,660
Quite right Tim, and I've posted as much previously. Sufficient knowledge of a wide range of subjects is more useful than specialised mastery of one, and it makes life far more interesting.
scarrabri
248
Stoke on Trent
Well spoken shep ,i too like the kettle plug,and the zoom forks are excellent in my opinion,gives a reall good ride ,best wishes BRIAN .
Blew it
1,472
97
Swindon, Wiltshire
There's no need to worry about the kettle plug on the Tonaro Bighit, the ground pin is at 90 degrees to the other pins. Only those most determined to be the next recipient of 'The Darwin Award' could possibly plug a 230 volt kettle lead into the battery.
