Buying First Electric Bike
DBCohen
155
Manchester
I admit the Prius is bigger and I should have chosen a bigger car to compare it with.
Be fair to Citroen though, they have been improving their reliability over recent years (they needed to!) though it is not relevant to the C1 / 107 / Aygo topic. I wouldn't pay more for the Aygo since the engine is identical (as is just about all the car). More importantly it is put together by the same workers on the same production line.
The Aygo, C1 and 107 use the same Toyota designed floorpan and running gear and are built in £1bn investment factory funded jointly by PSA and Toyota. The facility was designed and equipped by Toyota and can produce 300,000 cars a year. It is situated at Kolin in the Czech Republic which chosen because of its central European position for the supply of parts and because of the ample availability of less costly workers.
If you buy an Aygo then, you are paying much more for a badge. If you want an Aygo buy a C1 and then order a couple of badges from Toyota.:)
As for residuals just how much can a £5800 car lose in a few years? It may be a Citroen but it should still hold it's value well due to the low running costs and low insurance making it an excellent choice for a 2nd car / young persons car.
Hmm, I thought your 2nd car was an e-bike?
Good thing for PSA that Toyota runs the factory. I still reckon an Aygo will be worth more in the long run - memories of dodgy French electrics run deep.
allotmenteer
230
Aldershot, Hampshire
Yes it can take a long time to shake off a bad image.
I confess that we are a two car family :( though I do have a hub motor kit on a bike which I am now starting to use for commuting (16.5 miles each way). I am aiming to do it on a regular basis 2 days a week (at least during good weather / daylight).
I used the ebike on my commute for the first time last week and it took 1 hour 2 minutes (against 1 hour 13 mins on the unassisted bike) and I was not sweaty at all so didn't need to shower at work. I've only got a 24V system with a 15Amp controller so peak power is 360W. My goal for an ebike would be to get the journey time down to 45 minutes (though this would be 22 mph average!) but I would settle for 50 minutes (19.8 mph). I think I will need 36V to get that kind of speed.
I think a Torq or one of the F-Series would achieve this, so when I've got my money's worth out of the current kit (in terms of petrol savings) I shall look at buying one of the Eeze bikes (though there may be something better on the market at that time).
