I think that it'll be very easy to fit: take of your BB; slide in the motor and fit the LHS BB retainer; fabricate a simple bracket to stop the unit rotating; fit the pedal sensor, panel, brake sensors harness and throttle like any kit; fit the battery; tie down the wires.The kit seems to be easier to fit than rear hub kits. I reckon it would take me under an hour to fit.
I'd pick up a cheap second hand Trek on Gumtree for £100 buy a cd kit and presto, a 24mph e-bike.
Cheaper to run than a Boris bike.
I believe that Hatti is having the kit ones made to smaller size, providing there is enough interest for the production run to be economically viable.37mm instead of 35mm. What a shame
I think it's a dead cert that Hatti will order the kits judging the level of interest on ES and here. She should also take d8veh advice and get rid of the BB notches at the same time. By the way, demands for bottle batteries is high, I reckon it'll fetch £200 at least on ebay so you can probably halve the cost of the kit if you only want the motor.I believe that Hatti is having the kit ones made to smaller size, providing there is enough interest for the production run to be economically viable.
The good news is that for the peeps with lathes its only 1mm difference (lathe users will understand that, lol)
EDIT:- infact the conversion may be cheaper than a new production run (disasemble / 1mm off / re tap the thread / supply suitable 'nut') .. but of course thats putting it far simpler that it is in reality due to the existing bike frame requirements, but then that would be for the fitter to sort out.
No. I've got the Sirocco CD with 15 ah rack battery.Thanks D8veh for your work. Have been waiting for these results.
Looks to me like its a good bit of kit. Im hopefully going to Redbridge on the 7th to try hub vs crank but so far from what i've read crank seems to have made the hub motors obsolete.
From Hattis reply (email) it would seem that the kit will be coming with the 9ah battery only and cannot be removed for a cheaper price. This would be my only problem with it but looking forward to your results from your longer run to find out the range. Im guessing you have the 9ah bottle battery?
There's been a big fight back by old and new makers of hub motors though.from what i've read crank seems to have made the hub motors obsolete.
