The freewheel is steel and the motor is aluminium, so of you heat it up a bit, it'll come off easily.
Not as ideal as some internals to repair, most have the halls on a small circuit board which would make it easier to replace the halls, I wonder if this type is cheaper or easier to assemble.
I have a spare internal motor and I am planning a new build when the right bike comes along so I see no need for my spare... However there is a few points I should note, I deemed it faulty, it ran but did have that annoying click off click on at high speed or under load, that in all fairness the community never did quite explain and others reported a similar issue, neither the Dillenger nor the Yose 250 Front ever experience this, I put it down to either a fault on the motor or the controller. I was saving it for the 9 pin cable in case mine gave up the ghost however these are now wide spread and I shouldn't have a problem getting one if the need arises.
If you can not find a solution to your issue you are welcome to have it for the price of P&P and if it works for you then a small donation to my future projects if you can afford it, if it doesn't work then no worries. Hermes will ship it for about £10.00 but prices have risen since I last posted something out.
Apart from what I said in a previous post about a short, the only other logical cause would be that your ground wire is interrupted, so test for continuity between the thick black on your controller and any of the grounds of the hall sensors if you can get a probe to one.
The 4th sensor is the speed sensor for the LCD speed display.
Thank you for taking the time to reply. I may have found the issueHi, I spent a while trying to trace a simlar problem on my motor, yours has lots of insulation which is nice but makes testing difficult. It looks like all your black earth cables go into a single joint with heatshrink over - that might be the easiest place to get your meter probes. I added an extra earth wire just to test my hub, useful but I still have problems. Once you work out where the problem is I think your easiest option is just to replace the faulty bit(s) unless you like a challenge and want to try fixing the fault. Good luck, ive written about it above.
Now that you've eliminated an interrupted ground, the only logical cause of all three halls not working is a short to a motor phase wire. Did you check the motor cable very carefully?Thank you for taking the time to reply. I may have found the issue
That wouldn't stop the halls from switching. One thing occured to me. Maybe you have a dual mode controller that's been running sensorless. Try resoldering that blue wire, then see if it works..Hello. When I set the meter to 20k I get a reading of 13.60 or 19.99 at one point on all three phase cables soldered onto the board. However I get no beep of continuity between the blue cable in the julet which is soldered onto the circuit board? Have I found the issue?
The part which goes into the motor looks fine. However the wires in there could be still be broken of course. The rust on the wire is from the spring.Now that you've eliminated an interrupted ground, the only logical cause of all three halls not working is a short to a motor phase wire. Did you check the motor cable very carefully?
This would be a good long term solution. Pity im not skilled to change the cables. Good idea thoughtEverything in the photos looks good to me. There's still the possibility that something happened ages ago and it's been running sensorless until it got a new problem, like a popped mosfet. You could buy a new dual-mode controller and see how it runs sensorless. They normally run pretty well.
24V/36V48V/60V 250W/350W LCD Brushless Motor Controller Battery Speed For MTB E-Bike Scooter
Only US$61.73, buy best 24V/36V48V/60V 250W/350W LCD Brushless Motor Controller Battery Speed For MTB E-Bike Scooter sale online store at wholesale price.uk.banggood.com
My controller over heated when I was claiming a hill on a sunny day. It's an 22ah and I had set the the controller to only take half that amount which is level 5. After that I went to level 3 which I believe is a third of the power the controller can give. I would have thought having a high rate controller yet using only half it's output would keep it cooler than the standard 15ah due to it being larger with more components? I also opened the bag it was in so air flowed through the heat sinks.I got a nice dual voltage, 14a sinewave controller, however it is black and gets cut out hot in the summer, it was out in the open to boot, albeit it was 27 degs+ and no wind. But it looks amazing spesh now I put some gold heatsinks on it, whether they'll work or not remains to be seen. Oh and its julet.
Waterproof Connector for Electric Bicycle, Brushless Controller, KT Series, LED, LCD, 36V, 250W, 48V, 350W, 14A, 6 Mosfet - AliExpress 18
Smarter Shopping, Better Living! Aliexpress.comwww.aliexpress.com
Aliexpress does take VAT at EPOS the last 4 items I ordered (throttle, cables, brake sensors & PAS)came from China and through customs and I assume they were delivered to a "warehouse" in the UK because they arrived via RM with tracked 48 labels on, no extra fees. They took too long and were internationally tracked to have been dispatch from the UK. However this controller was purchased a 2019.
