yesterday i had 1 ebike now i have 4!
4,215
The battery is too high and too far back. The bike will try bto flip if you go up a steep hill. Why can't you put it in the triangle?
If you had a normal rack, you could have it just above the wheel, which would not only shift the battery down about 6 inches but would allow you to get it right up against the seatpost, which would be a lot better.
You can make your own rack for next to zero cost if you have a hammer, a drill a couple of pieces of aluminium tube and a piece of plywood. You can use those two struts you already have. If you get one of those sports bags, you can stick your controller and tools in there too. keep it secure by zip-tying the zip if you need to.
I wonder what happened to all those old forum members. I think Awol is still active on ES and Danielrlee is still active here, but the rest vanished into thin air. They were happy days.
thelarkbox
1,675
520
oxon
Thanks for the link, and its certainly an option. the current rear rack mount was an idea, perhaps not a good one.. as i have swiped the battery twice with my size 9's getting on and off the bike just checking the brakes..
Inside the frame triangle is a no go unless i drill and rivnut 3 new holes and then its doubtful, and the crossbar had been predrilled for battery mounting.. its a non standard triangle in the frame with the front angle squashed somewhat as if the angle is heading towards 0.. check the pics.. im not a descriptive writer..
