YAMAHA EASY.. Old pedelec ebike but the 24v mid drive unit has potential
I was thrown a curved ball this week when I tracked down a mid drive pedelec at a local auction. (I acquired it for under £40).
The machine is a Yamaha Easy, (the basic one, not the Easy Super) and it once ran from a, now missing, 24v nimh 6ah battery. (That’s no problem because I make my own BMS protected lithium battery packs from 18650 cells myself).
The mid drive is old. (2003), the system is 24v, (different than all my other machines), and the battery tech is now out of date BUT none of those facts matter at the moment. All that matters, at present, is firing up the mid drive to see if it runs.
So … a few questions
1. Is the Yamaha Easy also known as a part, product or model number?
2. Can anyone provide the Yamaha Easy’s mid drive ref / unit number and spec / wattage?
3. Can anyone provide correct wiring detail for Yamaha Easy battery case in relation to the 3 pin interface it attaches to on the bike? (It looks similar to an early Giant battery pack).
Viewed from the (missing) keybarrel entry hole, (on the left side of the machine), I can peer within and see that the 1st pin has a heavy duty RED wire attached. The 2nd pin, (in the middle), has a heavy duty black wire attached and the third pin has a thinner pinkish, (possibly faded red) wire attached.
4. Can anyone confirm pin arrangement / voltages in relation to above? Does anyone know what voltage goes to which pin? Or what the thinner pinkish cable serves? (The sensor? The PAS?)
5. Can anyone furnish me with any other technical detail?
Thanks,
Beach
  • Replies 112
  • Views 16.8k
Thanks LeighPing. The link looks useful, particularly with regards to the diagrams. I may have a challenge converting the text but at least I have something to go.
Thank you for your prompt response. :-)
And ... of course ... a grateful acknowledgment to Flecc for providing the original link to the useful PDF document it illuminates. :)
There's a few here that speak French. I'm sure they'll help you out. :)
Mmmmh. Trouble is, as Flecc points out, while the mid drive motor may be similar, the actual bike being referred to in the PDF is a different model.
If I were to focus on the most important piece of information I wish to uncover, it would be the following.
Do true pedelec* cycles with battery packs of the three pin interface variety share some common, generic wiring arrangement?
I ask because unlike a throttle based ebike, a pedelec machine assists and compliments a rider once the rider starts pedalling thus, I'm assuming, (guessing), that the thinner pinkish wire connected to the furthest of the three pins I outlined in text, (above), MUST carry a message similar to a sensor informing a regular throttle based machine that it is 'on the move'.
The Yamaha Easy has an OFF, ON and ECO switch which, presumably, manages (or informs)) the PAS. (Power Assist System) through such settings.
Is there some example of a typical PAS 3 pinned / 3 wired setup somewhere via a link online? ... or, (if there is some sort of generic setup), can anyone here enlighten me on the possible wiring arrangement I would expect to see?
Having reduced my own questions to this possible line of enquiry, I'll look online myself but if you can help, please feel free to add your thoughts here. :-)
Beach the thin wire is unlikely to control the drive. The battery voltage feeds control and motor via the control unit. The wire may be supply for switching on off that's common practice.
But this is guess work from me.
Google translate is pretty good. Reading the French notes, I've just established the similar bike described in the PDF has a superior torque sensor rather than a basic movement sensor.
Flecc. May I ask? Referring to earlier posts specifically discussing the Yamaha Easy elsewhere on this site, you seem to have some familiarity with it.
Can you recall if it too has a torque sensor?
I ask because I'm anticipating that my earlier request for 'generic wiring' info might be innapropriate ... if there are at least TWO possible options due to two differing sensor types having to to be considered.
Hi D8ve, Long time no see! :)
OK. So the little rectangular control box on the handlebars, (OFF, ON, ECO), plays a minor role? Simply taking power from the thin wire to either switch on, (or prepare), the motor, (Regular) or switch on in ECO mode? ... possibly?)
And then other circuitry or some mechanical process (currently unknown or invisible to me), reacts to the torque sensor, distributing power accordingly?
I've never come across one of them before but they seem very clever / very efficient in, seemingly, "knowing" how much force a rider is exerting ... and either matching that force (ECO) or doubling / tripling the riders own input , (Regular ON mode).
I know that Kalkhoffs, (and others), can have several individual settings but I'm happy to just get my head around the two on the Yamaha Easy for now. :)
Just chatting now as an aside but ... do mid drive units normally have what we might describe as regular 'Controllers" ie a controller described as, (in this instance), "a 24v 200 watt (or whatever) controller unit?"
Or does the mid drive unit present us with an entirely different means of controlling it?
Here is the drive unit ... and here's an intriguing thought ...
The unit looks very bespoked ... and the actual bike has a weird frame, (certainly not like a regular familiar frame) SO ... until I were to dismantle it, I'm of the opinion that it is unlikely that the unit could be removed and installed on some newer, more traditional frame ... though I might be wrong and, perhaps, by rotating it and making use of some, currently, unused spare threaded lugs, (covered with rubber bungs at present), it might just make itself a portable mid drive I could use elsewhere.
Unit.thumb.jpg.9b3d2bdb3b0a7887558d5d97c6142c5f.jpg BELOW are the three lugs or pins or blades ...
Is this setup an industry standard ... or was it ... in the days of Nimh batteries?
Pins.thumb.jpg.e5f91a78ab00e55ae3e4f15791d2a8cc.jpg And here, (below), we can peek inside the empty key barrel assembly and spot the heavy duty black and red cables in the foreground ... and the other thinner cable beyond. (Unless I can crack / resolve / complete this simple looking puzzle, I can't easily test the motor).
Frustrating, eh? All I need to know, (based on building a replacement 24v lithium battery), is what voltage goes to what pin?
I read elsewhere online that, possibly, the red wire takes + 24v, the black takes the earth / negative - and the little wire takes 12v, (The arrangement sounds similar to what D8ve stated re delivering voltage to the controller / box), but the info was written so ambiguously, I wouldn't dare try that unless I got some consensus here.
4.thumb.jpg.118a1416a53f1a4620957dcdf159444d.jpg OK. She's not a looker, (below) but ... allegedly, while a basic workhorse running on only 24v, she can climb walls with that efficient, clever, mid drive unit. (I say clever but that is only true if we assume she has got a torque sensor). In any event, she only cost me £35 at auction.
Edited by Beach Thorncombe
Simply the little switch box sends a signal back to the control unit in/around the motor. Turning the cranks is sensed and the pressure applied activates the motor in proportion to how hard you press on the pedal.
More details of the way it's done on flecc's informative articles.
Just follow the pink wire to see where it goes! Drag the motor controller out and show all the wires. We should be able to decode what's what. Follow the two thick battery wire, which go directly to the motor controller.
I haven't had the pleasure of viewing Flecc's articles yet. (Didn't realise there was such a resource here ... but I'll be all over it later today!) :-)
Well. I've discovered a plate that tells me what model number the Yamaha Easy is. It is an X99R. (It was hiding in plain sight on a label in the lower vee of the frame).
The plastic casing or 'pot', (probably hiding some electronics), simply refuses to budge, lift off or decant from the top / side of the motor though. :-(
There are slots indicating some kind of wedge or lever action might release it but ... No ... It just won't move.
VERY frustrating. Disheartening ...
Pot.thumb.jpg.e0254fa531371d1017c1e26d2a053ba7.jpg One slot can be seen, circled in red, but even by using 'the law of the lever', it refuses to facilitate the removal of the plastic cover.
I think the bike is a very early, maybe even the earliest, example of a Yamaha mid drive unit on a pedelec so I mustn't butcher or damage the thing.
Dissection of motor parts to trace wires while in situ seems challenging / impossible at present.
Motor is stamped with "X07 - A0 9 4 S".
Can glean no further info anywhere.
I must focus on main objective of deducing which wires, (from some new battery I might construct with 18650s), would go where, (in relation to the three pins described earlier), and at what voltage?
Either that ... or I'd haver to fully dismantle / remove unit from bike ... (not a prospect I welcome right now) ... especially with that process offering questionable guarantees of resolving the puzzle.
Please help with further suggestions for identifying the mid drive unit / testing the motor / deducing the voltage parameters / offering advice re likely controller / OFF ON ECO voltages.
Thanks.
Last, left-field, thought of the morning ...
OK. We know that old fashioned nimh batteries didn't require BMS, (Battery management systems) which suggests there may be scant or zero exotic circuits in the battery pack?
That might mean that there could be only 2 potential voltage factors to consider ... with 12v and 24 volts being the two voltages to ponder.
24 volts connected to the black and red wires?
12 volts connected to the thinner ,controller' wire?
Unless, (unlikely?), a lower voltage 'controller' wire picked up the voltage of just one nimh cell?
That is unlikely ... isn't it? And fiddly and 'more work' and complication during the manufacturing phase?
I'm thinking / writing these thoughts out loud to, perhaps, nudge a reader into, maybe, recalling their own observations while tinkering with similar battery case setups.
Sure. There could be some titchy little electronic circuit in a battery case but ... is there? Has anyone knowledge of the inner workings of a nimh battery (case) setup?
Don't you have a 24V battery handy? I would connect temporarily to the thick black and red and try turning the bike on.
Could the thin red just be used for the LEDs showing the battery level on the handlebar?
I think that maybe you might have to drop the motor to get at a hidden screw for the controller cover if it isn't budging.
Hi Beach Thorncombe. I only had a brief passing acquaintance with the original Yamaha PAS model, though all three were very similar. They were only on the UJK market for about three years from 1999 since the Giant Lafree from 2001 on was far more popular with our e-bikers.
However, the Yamaha models were much more popular in France and ran there from 1999 to 2006, so it's likely that there will be much more information available there. So I'd suggest you join the French pedelec forum and ask there:
This is the entry link to join where you accept their terms and conditions by clicking J'accepte:
http://e.bike.free.fr/forum/register.php
That takes you to the page where you enter your details, you'll probably be able to decipher what is wanted to answer each question, but if not use Google Translate or similar or a French-English dictionary to check a word meaning. I've added translations below as a footnote:
The good news is that the page has a drop-down option where you can choose to use English instead of French in your posted questions!
Footnote
The questions in French you need to answer are your name and a password with password confirmation, which I'm sure you can decipher.
Then you are asked these:
Saisissez une adresse de courriel valide, that is your email address.
Then there's an anti-spam question which changes all the time, so ask Google Translate what the question means.
Then there's your time zone which is by default GMT.
Then the French or English language drop-down choice for your postings.
Then there's the choice of whether you want your email address to be shown to others. The three options in this order are in English:
Display your email address.
Hide your e-mail address but allow the form to send email. (This is the default)
Hide your email address and forbid the email sending form.
Finally the last question is whether you are remembered between visits. It's checked by default and they recommend that.
Hope this helps you to find some answers, they have listed forums for some named bikes and also one for "Other Makes" which will include the Yamaha.
P.S. The third battery connection on NIMH batteries are for the NTC thermistor that's in the NIMH pack. It's not needed when using a lithium battery.
