Will a Tongsheng Tsdz2 fit on this full suspension decathlon bike?
peter.c
1,612
493
thurrock essex
The dnm had no bushes fitted just pressed the one out of the standard shock and reused
mine has a 116 link chain 11-42 and 36 t on the front
8,641
Very snug fit.
UphillBattle
54
Found a battery 90 x 93mm that will fit in the large frame and can still remove it to charge
Now to find another
This battery case looks interesting - it might open up conversion possibilities for some other FS machines. Do you have details & vendor for it?
peter.c
1,612
493
thurrock essex
Thats the problem got the last two he had in the uk asked if he could get more he laughed
Do a google search for x go battery 48v 10ah but read the small print the newer one are in a larger case and 13 ah and will NOT fit
UphillBattle
54
It seems to be a Hailong G56, available on AliExpress from a variety of sellers in both complete battery and empty case forms. At around 9.3cm in height it’s around 1.5cm shorter than my Hailong with integrated controller. Maybe I’ll make a little cardboard template and try it in some local full-sus bikes from Facebook.0D273DFB-E71F-4685-8E5C-D46F6DC9AB7A.png
£34.74 3% Off | G56 G70 Battery Box HaiLong Battery Housing Down Tube downtube Battery Case For 21700 Cells 13S4P 18650 Cells 10S7P 13S5P 14S5P
StuartsProjects
1,820
1,025
The bottle cage holder looks like the same type that Eclipse use for their Supershark batteries.
If so you need to allow for 18mm space to pull the battery forward and 8mm to lift upwards so it releases.
Reactions: UphillBattle
Rt3005
25
So regarding the gearing, are the gears on the back wheel meant to be offset with a spacer to mesh properly with the motor?
AGS
608
190
I have a vintage Rockrider Fire with a BBSHD and I use a backpack battery with an XT90 connector under the seat. I wouldn’t be able to mount a battery on my frame. I also fabricated a bash guard for the motor. I don’t like the way the cables are so vulnerable coming out of the bottom of the motor. The white bits between the bash guard and the motor are pencil erasers hot glued to the case to provide some spacing for the fins and act as shock absorbers for the guard.
I got a perfect chain line using the standard Bafang chain wheel that came with the kit. It’s a horrible looking thing but does the job nicely for me.
A09914C5-C818-40D1-881B-DC5E2E4B61E0.jpeg36C61D4F-559F-4954-9125-AEF313739EFC.jpeg4E607E64-E7B2-46DA-90BD-140893704E22.jpegA09914C5-C818-40D1-881B-DC5E2E4B61E0.jpegA4C0F37A-0C51-41A4-9DD7-9ECFB1D39192.jpeg
Rt3005
25
i put a 42t on the front but even with that, however I set up the derailleur I can't get the bike to stay in a gear, it just jumps up and down out of gears
AGS
608
190
I originally had a triple chain set, so I disconnected the front derailleur gear change cable and adjusted the screws to set it up manually as a chain guide to stop the chain falling off. Maybe you could try that or fit a real chain guide.
Another option is to shim the motor in the bottom bracket to try to bring it into alignment. Shims come in various widths.
matthewslack
2,192
1,524
Are you sure it is jumping between gears rather than chain slipping on cassette?
If chain is correct length, cassette and chain in good order, enough spring tension in the derailleur then at least the gears close to the line of the chainring have to work! Even with a bad chainline, the higher gears i.e. smaller cassette cogs should work. If not, check for wear or just fit new chain and cassette.
If it is not slip, then start at the derailleur top jockey wheel. That guides the chain onto the cassette, so if in good order, jumping should not be possible.
