Whoosh Crank-Drive Tongsheng Kit review.
17,014
MikelBikel
1,210
359
Ok, so the frame can't accomodate an equivalent 13S battery, fair enough. Booster battery?
yes, it does, but the battery is only 36V.
If I were to build a CD bike with that frame, I would use the easier to fit 36V Gospade motor.]
17,014
I would need to buy 48V 10.5AH battery in the same casing. The cost would be the same.
Using the Gospade is a lot simpler. It'll take me half an hour to fit.
Eagle
381
134
Woosh,
For the benefit of members who may be contemplating putting the Tongsheng TSDZ2, or other CD kit, onto a full suspension (FS) bike, can you give suggestions for suitable candidates as donors?
Which bottom bracket types/sizes do the donors need?
The obvious problem is mounting a battery to a FS bike.
vidtek
423
243
Bournemouth BH12
it won't. The gearbox on the TSDZ2 is about 15mm wider than the gearbox on the BBS01/BBS02.
Whoosh- you didn't answer Eagle's question or perhaps you may need more time to consider?
QUOTE"
Just out of interest and for the benefit of other members, do you know of any suitable FS donor bikes for a Tongsheng TSDZ2 kit?
Woosh probably knows."ENDQUOTE.
I'd love to know too.
Cheers, Tony.
17,014
QUOTE"
Cheers, Tony.
sorry! You need the rear spring connected to the top tube and make sure that there is enough space for a 42T chain ring.
Something like this:
Eagle
381
134
Woosh,
Thanks.
Whilst pretty common in the USA, the Cannondale Rizes are a bit thin on the ground in the UK, so do you know of any other suitable FS bikes off the top of your head?
peter.c
1,612
493
thurrock essex
Before I built the zobop I walked into evans and halfords and decathlon with a card board cut out and a tape measure you can eye the frame up :) the bbs 02 or hd will fit into most bottom brackets 68-72mm 74-75mm at a push with a California ebikes motor mount ;).[even a cyclone 3kw:eek:]
The problem is the downtube battery packs a hailong pack might fit the type one is 90mmx90mm most shark or whale struggle unless the shock mount clears or build your own pack [mesure twice make sure to check at full compression of the shock:mad::rolleyes: i forgot a costly mistake ]
It is buyer beware on a donor bike will it fit or will it not on a fs bike, or you end up with the battery under the down tube try a google image search a lot of people use the lunar cycles mini cube pack
Have not fitted a tsdz2 yet but the lug mount anti rotation on the back might require an extra bracket fitted or a custom frame as the rear stays pivot on most fs bikes post a picture before you buy a donor bike
vidtek
423
243
Bournemouth BH12
Thanks Whoosh for this. For those new to bikes like I am/was a few short months ago, the technical drawing of the motor does not show this absolutely critical measurement when contemplating if your bike will be suitable for a crank-drive kit. I have marked where it is in red. This may seem very basic to you experienced guys but believe me when you know absolutely nothing about bikes it can be very confusing.
peter.c
1,612
493
thurrock essex
Have seen one with bbs02/bbshd fitted and a hailong 2 battery the rear anti rotation bracket on the tsdz will require a bracket made to work
Crossroads
89
49
Richmond Hill, Bournemouth
From Bournemouth Square to Richmond Hill Roundabout is .23 miles
An ascent of 92ft gradient varies, but up to 10.8% .
Source Mapometer.
Know it well
vidtek
423
243
Bournemouth BH12
Source Mapometer.
Know it well
Crossroads,
Thank you for this, I just know it's a really steep one with a silly cycle lane.
Tony.
divingshrek
Another critical dimension omitted from the drawing is the radius of the gear housing. On my Nucleus 275 the chainstay is 7mm outboard of the BB at that distance. I suspect many MTBs with 2"+ wide tyres are going to have this issue.
Cheers
Ian
DavidSWP
40
57
Woosh,
I have a TSDZ2 fitted to a 2007 Specialized Stumpjumper. It is brilliant.
The only fitting issue is that you can't secure the anti-rotation bracket to anything. You would struggle to incorporate the anti-rotation feature on any full-suspension bike to be honest, because the bit of the bike it normally secures to moves up and down. The motor doesn't rotate anyway as long as everything is nicely tightened up (250W 36v)
Don't get a Stumpjumper later than 2007 though because I believe they changed the bottom bracket to a more non-standard one.
Reactions: M1watch
cycling weakly
93
21
78
With the suspension bottomed out, the motor must be very low. I gave up on the idea of fitting a BBS into a stumpy because of this. Any bike with a modern bent downtube will have the same problem when ridden on rocks & roots.
Steve.
Reactions: M1watch
OldManToy
12
Hey everyone, that Gospade system looks interesting and I like the bottle style battery. I might be missing something but I can't find it for sale in the UK. Can anyone help with that? Or do you have it @Woosh ?
17,014
good morning OldManToy,
I only have a sample of the Gospade that has been modified for me. It's a very interesting design which should be easily modified to work with different bottom bracket types like Press Fit. That's what attracted me to the Gospade. I still plan to bring them in this Autumn.
If you want to buy one, contact Gospade directly. They are slightly cheaper than Bafang.
OldManToy
12
Thanks for the advice. I've emailed them. Have you used your sample unit enough to get a sense of it? I'm interested in responsiveness from a standing start and robustness. I'd only be commuting 8 miles each way. My objective is to avoid breaking a sweat, which currently happens due to two slight inclines.
