What are they like to ride?Finally have made mind to buy one of these. Both are in similar price range. Volt is 1 kg heavier but 1Ah extra with suspension and disc brake. Anyone has any opinion, reviews?
You will have a better feeling of what bike works for you after you have ridden it.I am going this afternoon to Volt shop and probably tomorrow to try Kuo+
Many thanks. I ended up buying 2 volt metro. One for me and another for my wife. Ridden for 2 days now. Liking it so far.I have had my metro for 3 years now it's solid and dependable. The front light is a bit underpowered though it's a generic one and is the standard on most e bikes. I would have preferred if the back brake was also a disk though the V brake does the job. It's also very easy to set to off road mode if you feel the need for a bit more speed.
The Guys at Volt have given me good service the couple of times when I needed it.
Give the dealer who sold it you a call he will tell you.Many thanks. I ended up buying 2 volt metro. One for me and another for my wife. Ridden for 2 days now. Liking it so far.
Btw how do you setup the off-road mode? Can you please post steps to do it? By doing so Does it void warranty?
Thanks!! Great tips. So, if I have any problem after changing the settings and I revert it back to default settings later, would the shop be able to find out what the settings were?You do it via the LCD screen. Yours screen is a the updated version though I suspect it still the same. Hold down the menu button until a 2nd screen appears adjust the no you will see using your up button on mine it goes from 26 to 28. The screen will then revert back to normal. Depending on your weight you will get a bit more speed. I get up to 22mph.
It will however void your warranty if you have a problem though it's easy to revert back to the factory setting.
No, I didn't. I was waiting for 10 days to get the stock and still the shop did not get back to me till now. So, I realise volt was the way to go.... and I am happy with it TBH.I guess not.
But did you test ride the Kuo+ before buying the Metro though?
I didn't really weight it as such, just took it for granted what says on the website. So with a 16AH battery it comes 22.9Kg. Its on the heavy side. but if the battery is removed it becomes a bit lighter to carry up the stairs. But its still heavythat's good. They come with 2 years warranty as standard.
so did you weigh the Metro with battery?
Thanks for the tips!!!Watch out for the throttle when the battery is low it has a tendency to stall.
