Only the signal wire will have voltage going up and down!On the Voilamart controller throttle, there are 6 cables, doesn't shorten the odds by much.
Yes, but that needs to be explained to MikeOnly the signal wire will have voltage going up and down!
Dont hold back wheezy . Which one is the signal Plz ? Please Leave Me out of your verbal battles I need all 3 of your inputOn the Voilamart controller throttle, there are 6 cables, doesn't shorten the odds by much.
If White is present it should be the signal wire, Black to White 1v & open throttle about 4v should register.Dont hold back wheezy . Which one is the signal Plz ? Please Leave Me out of your verbal battles I need all 3 of your input
Don't worry about us Mike, we're just a bunch of cantankerous old men who aren't getting any younger, and are certainly not getting any prettierDont hold back wheezy . Which one is the signal Plz ? Please Leave Me out of your verbal battles I need all 3 of your input
ThAnks . I was jokin really . I quite enjoy your verbal jousting haha .Don't worry about us Mike, we're just a bunch of cantankerous old men who aren't getting any younger, and are certainly not getting any prettier
I wanted to have a proper look before I posted, I didn't want to be saying the first thing that came into my head so this morning I did some testing.
As you know, there are 6 wires, Yellow, Brown, Green, White, Black and Red.
The switch on the throttle unit activates the yellow and brown wires. The brown wire is at battery voltage.
Yellow and Green are connected together on the controller board.
Black is ground. Red is about 5V, but this is only active if the throttle unit switch is closed.
As Nealh suspected, the white wire is the throttle signal wire and I measured this to vary between 0.8 and 3.6V, from the throttle being in the off position to fully on.
You can poke your multimeter probe tips into the backs of the controller/throttle connectors when they are connected. Do this on opposite connectors to avoid shorting the probes. This way you can check the throttle without the motor being connected.
I'm not sure which wires correspond to the LED voltage gauge, I imaging it will be the green wire, but I will need to do a bit more testing to pin that down for certain.
Wheezy should the pedal assist work irrespective of whether the throttle is working or not ? It's me that mentioned the throttle I know but if the motor should work eventually with only pedal assist I'd rather solve that first then check the throttle cis it's a pig to get at . Then I can try and work out how to get these halls off the PCBDon't worry about us Mike, we're just a bunch of cantankerous old men who aren't getting any younger, and are certainly not getting any prettier
I have never used the PAS on my Voilamart controllers. However, I have just been in the garage, connected the PAS with the throttle switched on and waved a magnet at the PAS and yes, it does operate the motor without the throttle being twisted.Wheezy should the pedal assist work irrespective of whether the throttle is working or not ? It's me that mentioned the throttle I know but if the motor should work eventually with only pedal assist I'd rather solve that first then check the throttle cis it's a pig to get at . Then I can try and work out how to get these halls off the PCB
Anyone ?
Gotcha but wouldn't PAS work without throttle on a working bike Anyway? After all if you were using pedal assist you wouldn't use throttle necessarily at same t imeI have never used the PAS on my Voilamart controllers. However, I have just been in the garage, connected the PAS with the throttle switched on and waved a magnet at the PAS and yes, it does operate the motor without the throttle being twisted.
When you do your tests, unplug the brake to the controller cables, just in case there is a short there that is stopping the motor from running.
.my point was more about if the throttle was faulty disabled blown whatever , would pedal assist still work ?
Yes I can confirm that with no throttle attached, but the yellow and brown wires shorted on the controller throttle connector, the PAS alone will make the motor run.I'd like to say yes, my other bike works fine without a throttle attached at all, but that has an LCD screen to control it... but the Voilamart needs the on/off button of the throttle to turn the controller on. I'll have a go at leaving a throttle completely detached and turning the controller on without it and see if the PAS runs. I'll let you know.
Thanks wheezy sorry it caused a short. I'll plough on with removi g the sensors but sorry I need help for this . Looks like the sensors pins below the board are either glued or wrapped . Dunno best way to remove themYes I can confirm that with no throttle attached, but the yellow and brown wires shorted on the controller throttle connector, the PAS alone will make the motor run.
Oh no, it didn't cause a short, I shorted the connection with a piece of wire, so that the controller would switch on without the throttle connected.Thanks wheezy sorry it caused a short. I'll plough on with removi g the sensors but sorry I need help for this . Looks like the sensors pins below the board are either glued or wrapped . Dunno best way to remove them
Good. Cani u help ref removing the sensors ? IM not sure how they are attached below the board see my photo on previous post don’t know if they’re glued underneath can u adviseOh no, it didn't cause a short, I shorted the connection with a piece of wire, so that the controller would switch on without the throttle connected.
