I’m lost . You’re saying controller end to circles and vfr is saying cross color test at controller end and continuity from circles to just outside axleJust start with step one and report back.
If you have different opinions I’ll just have to do both waysI’m lost . You’re saying controller end to circles and vfr is saying cross color test at controller end and continuity from circles to just outside axle
My way is much easier and quicker, plus you don't need to disturb the insulation on the joints in the motor. IMHO, the way he said to do it is daft. The results are the same whichever way you do it.I’m lost . You’re saying controller end to circles and vfr is saying cross color test at controller end and continuity from circles to just outside axle
Ok I’m sure I already did cross colour test from you’re earlier instructions but I’ll repeat it . The test from inside to just outside axle remains to be done.My way is much easier and quicker, plus you don't need to disturb the insulation on the joints in the motor. IMHO, the way he said to do it is daft. The results are the same whichever way you do it.
Actually, the way I said, you only have to check from blue to green and blue to yellow, and to check for shorts, you only need to check blue to axle when you have a meter that beeps, so only half as many tests as his way.
When you check continuity between any two phase wires, you go through two phase windings, so you check them both at once.Can you explain in a bit more detail what you mean vfr? If the number of tests can be reduced, I'd like to know.
So, you are saying unplug the motor from the controller, and connect the continuity tester (multimeter on 200 Ohms) across the different phase plugs of the motor?
The phase coils are connected altogether in a star formation and have a resistance that is too low to give a sensible answer with a basic multimeter, how is that going to give a good indication if there is a short/break or both somewhere between the connector leads and the motor windings? If there is purely a complete break it might tell you something, but not everything you might need to know.
My method is a bit more long winded, but from it you know for sure what is what and I think it's also more in line with Nealh's method. Are we missing something?
The phase windings have such low resistance that you can consider them a direct connection.
If any of the wires were shorted to the motor chassis, effectively, they all are, so you only need to check one.
If the wires are shorted to each other, you'd need a special meter to detect that since they're all connected in the windings, so you'd need to see the difference between zero ohms and 0.1 ohms, which your average DVM can't do.That's good, but what if you have a short at the point of the twist, that also does not short to the axle hub?
Work wise busy so looking like phase wire test by Friday and attempt to remove sensors weekendIf the wires are shorted to each other, you'd need a special meter to detect that since they're all connected in the windings, so you'd need to see the difference between zero ohms and 0.1 ohms, which your average DVM can't do.
His wire got twisted where it comes out of the axle. Some wires must have shorted to each other to damage the halls. His repairer has pulled the damaged part through, then cut and joined the phase wires, and he cut and re soldered the sensor wires. There's clear evidence of that, so it's extremely unlikely that there will be any damage remaining.
Now that we have most of the story, it looks like the guy did a reasonable job of the repair. The soldering doesn't look particularly good, like he used lead-free solder without extra flux. The main thing is that he apparently used the wrong type of hall sensors, which will be confirmed if and when OP gets them out.
I see. Your test would show if there is a break in a wire or a short to the axle, but it wouldn't clarify all potential cases. This is why I said to probe each wire from the controller end to where the same wire meets the windings in the motor, that way you can be sure the wires are continuous through the region of the potential break or short. I would do this test if probing across phases and the axle body didn't show anything untoward.If the wires are shorted to each other, you'd need a special meter to detect that since they're all connected in the windings, so you'd need to see the difference between zero ohms and 0.1 ohms, which your average DVM can't do.
Which is signal wire plzWith the controller switched on, measure the voltage between the red and black wires on the throttle, then measure between black and the signal wire while you twist the throttle. The two results should be 5v and 1,2v - 3.8v.
Because they just used the first thought that came into their heads instead of thinking the problem through.Question to all 3 please . I may misunderstand . But why does Nealh and wheezy cable test involve cutting insulation at motor end but vfr second test to just outside axle only involves getting a probe below the shrink wrap
now now does t break up the team spiritBecause they just used the first thought that came into their heads instead of thinking the problem through.
On the Voilamart controller throttle, there are 6 cables, doesn't shorten the odds by much.The one that's not red or black.
