Such a good idea. Yes that makes sense re the campsite. Do you think a 270 rpm bpm/cst could cut it, with a trailer?I'd take a spare battery and charge it while travelling.
But surely that means you'll be riding along with an internal combustion engine going (unless I'm missing something)? In which case a scooter is a far better bet, surely? They are common, cheap, only two wheels to worry about, reliable, comfortable etc.Such a good idea. Yes that makes sense re the campsite. Do you think a 270 rpm bpm/cst could cut it, with a trailer?
Purely depends on the battery cells and the BMS. I've charged mine at 8A - it's a 10s4p pack so each cell is seeing 2A charge current. The cells are Panasonic NCR18650PF which have extremely good current loading characteristics both charging and discharging - they are very close relatives to those used in Tesla cars which I believe are charged at 4.4A per cell initially when supercharging. However other cells are likely to not be as resiliant to high charge currents. The only way of telling whether it'll be safe is by identifying the type of cells in the battery.I've been reading about the Cycle Satiator charger, 1kg and charges up to 8a. That would charge most batteries in under two hours -but can the batteries take it? If so it would seem a potentially superior solution even to a second battery, let alone a generator. One could just buy a coffee, have a read and it's done.
