Upgrade - Ananda MC5-B0 Controller
8,616
Ok thanks, it should work then one would have thought.
wilhian
30
Install torque sensor.
When pedaling, the engine is activated, but it turns in false, it does not transfer the power to the wheel.
This happens when I pedal or use the accelerator. The engine starts and makes a running noise, but the wheel does not turn.
Any suggestion ?
wilhian
30
Any suggestion ?
Any suggestion ?
Information:
The seller informed that the new kit was for the bafang engine, so I asked here if there were communication protocols with the engine.
Is there really a mismatch?
The engine starts and makes noise, but there is no force on the wheel. It seems that some feature to give the wheel traction does not work.
wilhian
30
Information:
other information:
Motor connectors are the same, plug and play, but how do you know the pin sequence is correct?
8,616
Motor connection sequence on the 9 pin motor connector are std and don't differ it is the only bit of wiring that is generic. I have used Bafang, AKM, Yose and MXUS all are the same.
What may differ is the phase sync and the controller may not be reading it correctly, does the lcd display have a setting to change the phase parameter ?
For instance some of the crappy controllers use learn wires and the KT lcds can change the phase sync in the settings.
wilhian
30
I don't have phase settings on the display.
The engine starts and makes noise when accelerating, is the engine running backwards?
8,616
Describe the noise, if it is is an electric cracking noise then it is phase out of sync and one will damage the controller riding like so.
wilhian
30
it is not cracking noise.
The noise same electric motor.
I can't attach the video. says the extension is invalid. Does the forum accept any kind of video? how can i send you?
8,616
wilhian
30
Manual for Intelligent 850c .
Microsoft Word - 850C Specifications-5S 2016 (1).doc (emubikes.com)
Just in case the controller isn't configured correctly there ae advanced options to check motor direction and halls are switched on.
Are there any error codes ?
my display is p850c, it doesn't have these options in Advanced.
if I keep accelerating for a while, even without the wheel turning, error 21H appears but i believe that 21h is because it is not increasing the speed.
Do you have an email to send you the video? it really looks like it's phase the problem.
is it possible to update the display firmware to have advanced options?
inside the controller may have phase configuration jumpers?
8,616
8,616
The file opened but I couldn't hear anything.
I can only suggest it is a set up issue or the system needs a factory reset/restore in the settings.
I think I mentioned it early in the thread, I just don't see much point in trying a TS system on a hub motor.
Reactions: wilhian
FourZeroOne
Dec 28, 2021
Hi,
assuming that the hub motor does have free wheeling, I believe that - yes - the motor is running in reverse direction.
Reactions: wilhian
wilhian
30
Hi,
Thank you very much. With your help I identified the correct wire sequence.
I cut the wiring and assembled it with the new sequence.
Now it's working.
My engine was running backwards, and due to the clutch it was running but not turning the wheel anywhere.
In the document you sent, there is a scenario like this.
Thanks to everyone who helped me. Including who made the wiring document. Very good!
Reactions: sjpt
Landimfilho
Feb 13, 2022
Olá,
Eu tenho uma bicicleta elétrica e gostaria de atualizar o controlador e a tela (continuar com o motor).
Minha configuração atual é:
Ananda Display D15
Controlador Ananda MC5-B0
Motor/Motor
SN M129321199144
AN T0050011-1011400035-00
36V 250W 29 "P8
Minha pergunta é:
Ao perguntar ao fornecedor do controlador/display se era compatível com meu mecanismo atual, eles me perguntaram se o protocolo do mecanismo é 5.0.
Não encontrei a informação. Não sei se o controlador ANANDA MC5-B0 é protocolo 5.0 e não sei se o motor é protocolo 5.0.
Como posso encontrar esta informação?
Obrigado,
Wilhian,
[/CITAR]
Cilliam
Fate_B
Feb 22, 2022
Hello, I also own a Oggi BW 8.0 which I use daily for comute. Recently I got involved in a minor accident, but the D15 display cracked (still works). I'd like to know more about the results of your new configuration, if you noticed any change in battery range, I ride about 50km with a full charge.
Also, how's the torque sensor perfoming? Did you feel any diference from the original?
Thanks.
wilhian
30
Thanks.
Hi,
With the torque sensor it is very different.
You need to apply force to the pedal to start receiving electrical assistance. If you pedal without power, no electrical assistance is applied.
Normally the panel shows help from 80w to 120w. If you pedal standing up, applying a lot of force, you can see 200w, 250w assist.
When using the throttle, powers between 300w and 400w are used.
In my opinion, the torque sensor could be more sensitive or have an adjustment. When I don't have the expected assistance, I use the throttle.
I believe that using between 80w and 120w the autonomy will increase, but I rarely use the bike.
