I may have been on EddiePJ's list.Deleted it as I posted it in wrong thread.
If you don't know who is on EddiePJ's ignore list, where have you been.
Well, you did call him worse than shite on many occasions.I may have been on EddiePJ's list.
It's because I can't see into the future.Have been? Past tense..
The battery is the thing not to skimp on cos however big it is it won't be big enough. I went from a 400 to a 500 and the difference is that the display segments last that little bit longer.i did a test ride on a trek powerfly f7 2016 today at allterain cycles with 25%off 3100 down to 2337 when i rode it it had a 500w bosch battery on it but online its says 400w do you think its still worth it and is there much difference between 500w and 400w thanks
Not for another 33 years he is young and fit and likes a good workoutGreat.
Luke soon to be looking at eFat bikes?
hi did you also consider the LT long travel version? Its sold on the 9 but nots sure if the 130mm travel is enough?
Hi Mr T Yes I did look at the longer travel version but decided 130 mm was plenty for my riding .hi did you also consider the LT long travel version? Its sold on the 9 but nots sure if the 130mm travel is enough?
Is that the Yorkshire section of the M62 or Leeds bypass ?it was plenty good enough for these rocks
