Expected on going expense - something equal to the national debt of a small country, some one (dam them) will always be posting about some must have gadget / device, also I doubt you will be happy 3 days after the bike is complete as you will notice things that are not quite right and need to be done differently, also spare parts need to be at hand, and not have to wait upon deliverys from the east ..
Expect plan b - there's should always be a plan b, like a trailer for all your gear
Yeah you're right about ongoing expense. Though bar breakdowns the thing I'm interested in other than keeping it functioning this year is basically the Speedict options and possible potentiomenter. No doubt more things will emerge - but if I have something which works well enough and I'm not there all the time chances of my tinkering too much once it's built are pretty slim to be honest. If it lived with me full time I'd be adjusting things constantly to get that extra bit of perfection
Viz plan b ... been through that though process before and concluded I'd likely never use it. Too much faffing about, hard to secure, impractical off-road, not great on potholed windy narrow country lanes you can barely drive along with rivers of water flowing on either side 12 months of the year. Need to think off-road rigour rather than town/village to steer the solutions on this one, I reckon.
Can't help wondering whether something like this is the obvious solution (similar to post above) :
Mtbr Forums - View Single Post - How to sew a frame bag. Long and pic heavy.
Would use a long strip of material for the velcro strips rather than several short ones because it looks better if the fabric is a different colour to the frame. Unless I can get one in shiny aluminiumcolour that is
.. also to make sure it's reinforced inside so as to hold its shape and not sag and look untidy.
The battery is quite short and fat, but it does just fit in the triangle. It's 160mm x 220mm x 90mm
So 3 1/2" max width. Should be OK to ensure adequate pedalling clearance either side in theory. Only thing is the connectors (for charging ?) coming out of it are quite chunky and cables quite short so I haven't worked out yet how that would work.
Controller siting is the other important consideration. Does this need to be close to the battery or near to the handlebars etc ? Does it make any difference other than wiring length ?
Only place I can see that the controller would fit without limiting the tyre width options would be in the triangle bag. It would have to go in the narrow part near the handlebars to fit the battery in. This would mean it could not be fixed rigid to the frame so my guess is that wires may shake loose.
I have also looked at the torque arm setup ... still cannot see where the arm would fix into on either the drive or non-drive side - will need more thought !
Beginning to wonder whether to sell bike and buy cheap hybrid with a frame that is designed to accommodate lots of fixings to hack around with, drill at will etc etc. Thing is if I'd wanted to do that (and lose my gears) would just have bought a kit at less than half the cost !
... definitely more thought required before going ahead with any build. I would like the final performance, but if the bike's utility and versatility gets taken over by that then it winds up not fit for intended use.
Must examine all options with this bike first before writing off converting it as "not for me" .. but I need to be able to understand and see clearly what the finished product is going to resemble and think through whether that is something I will want and use before getting underway.
Can still take back most of the specific tools and extras I've bought and get my money back from the retailers. Must keep remembering this .... bit stressed by it all now !
