No, it's as far forward as possible with NCX seatpost.Can the seat slide forward a couple more inches on the mounting rails?
Probably too early to get feedback on whether the ones you ordered from eBay have fitted OK, but could you let me know which ones you ordered - there are so many different ones listed on eBay!. ThanksFrom Ebay £13.99 Freepost. I have to double check the diameter first. You will be surprised at how far those cables will reach. Look at the photo of my bike above with Northroad swept back handlebars. http://www.ebay.co.uk/ulk/itm/401165154595
To enable my WingLights indicators to be seen i fitted these swept back handlebars. There is plenty of room for the fittings on this style and the bike handles great. You can sit upright or lean. Please note - my bike is the Big Bear so i don't know if your model will be the same for size / fittings.Probably too early to get feedback on whether the ones you ordered from eBay have fitted OK, but could you let me know which ones you ordered - there are so many different ones listed on eBay!. Thanks
OK. Many thanks. Yes, I have the Big Bear - the one with the "crossbar", just like yours. I would like to find some that are black though, rather than the chrome/silverTo enable my WingLights indicators to be seen i fitted these swept back handlebars. There is plenty of room for the fittings on this style and the bike handles great. You can sit upright or lean. Please note - my bike is the Big Bear so i don't know if your model will be the same for size / fittings.
http://www.ebay.co.uk/itm/Raleigh-swept-back-trekking-handlebars-like-north-road-/221427482646?hash=item338e1b4016:m:mNF5pEDddPUVwj0yvK_Ivyg
OR cheaper ones....
http://www.ebay.co.uk/itm/Retro-North-Road-classic-chrome-handlebar-58-cm-City-Dutch-Bike-Touring-Fixie-/152216416648?hash=item2370ce3188:g:o4QAAOSwMmBVkUvk
The actual basic cargo trailer is from Ebay at £83. The bits i've added to carry a person, a seat and back taken off an office swivel chair and bolted on, added stiff rubber sides and 2 rear bicycle mudguards. To comply with the law, two triangular reflectors, lights and a flag. She says it is so comfy and i don't really know that i'm towing anything!nice trailer! is it a bespoke one?
Is it possible to put the Big Bear motor on the back? I am a little confused by this thread. Perhaps you can if you dispense with the gears? Can anyone explain? Thanks.
Yes, that’s what i thought about keeping the weight on the front. I’m surprised to hear that the FUN motor weighs as much as 4.4kg ? I think putting a new back wheel with motor will be quite straightforward. The only problem could be the disc brake. May have to change to rim brake?Seems a bit point less riding around with 4.4kg dead weight not needed swap the front for a normal hub wheel an if happy with the rear set up sell the old motor wheel.
Or alternately with all the rear weight inc battery you may find the front becomes a little light on the steep hills so the extra front ballast may come in handy.
we can supply a rear Bafang SWX02 with disc brake rotor for £150.I am looking at the possibly of disconnecting the power to the front motor and buying a new back wheel complete with motor and gears.
Is that the same motor that i’ve got on the front? What else would i need to buy to make it rear wheel drive?we can supply a rear Bafang SWX02 with disc brake rotor for £150.
no, that the motor in the Bermuda. We also sell the motor in the hub kits.Is that the same motor that i’ve got on the front? What else would i need to buy to make it rear wheel drive?
