Torq battery dilemma
HarryB
1,317
London
That doesn't worry me Harry, I'd expect it to take that long or more anyway, hence the offer. It would come back to me as the weather started to warm, and that, combined with the Q bike efficiency would mean I got good use from it as well. I do in fact want an additional eZee battery case at some point as one of mine arrived cracked through, so there'd be an additional gain for me eventually anyway.
So up to you, if it's convenient I'm happy to go ahead and let the Halifax shoulder the cost for a year. They keep singing about how much they want to help us.:D
P.S. If you still are concerned at my losing value, you could include a cheque with the returned battery for say £10 a month used, thus paying for your part of the usage as you normally do anyway, though I'm not worried about that extra.
Flecc I have PM'd you with a proposal.
HarryB
1,317
London
I have ordered one of the new Li-ion batteries. I'll let you know if the new Battery Managment System is any better than the old one.
The theory is that BMS will tolerate a lower voltage for slightly longer before it cuts out. This will mean less cut outs when you snap the throttle open but I cannot see it making any difference when riding up a sustained steep hill. We shall see.
30,837
Thanks Harry, that's my interest as well, though mainly with the T bike as the Q gets by with low power applied.
Tiberius
919
Somerset
Ah, but can the BMS do anything about the cutouts? Are the cutouts we are experiencing done by the controller on the bike, or by the BMS?
Either way, they are in response to the battery voltage falling below a certain threshold under load. My understanding is that the internal resistance of the LiIon battery increases with age, and the capacity decreases with age. Both these effects will make the cut off voltage appear earlier and earlier in the discharge.
Nick
30,837
I don't think it really matters which Nick. What's needed is a battery that doesn't drop voltage so severely, NiMh for example. Just about solving the cut-out problem will only highlight the other aspect.
What gets forgotten in this debate is the severe loss of performance long before cut out when the voltage drops. On one very long climb I do, the performance continuously fades, the bike getting weaker and weaker and forcing me to do more and more, until eventually the first cut out occurs.
By contrast on NiMh, the performance is fractionally lower initially but only fades slightly, remaining reasonably constant for the whole climb. On the T bike radical battery I start with a higher voltage which offsets even that small fade and gives me a reliable more constant power under load.
HarryB
1,317
London
Nick
Yes I think the consensus of opinion is that it will not stop the cut outs as the cells age - thus my reluctance to buy another li-ion. The only way forward would be to increase the capacity of the battery as Wisper have done or perhaps higher quality cells. Needs must on this occasion and we shall wait and see.
Tiberius
919
Somerset
Here's another thought: has anyone done any proper measurements on these batteries? What do eZee and 50 cycles do?
If you look around, ebikes.ca publish some battery discharge curves but they are done at 1 Amp. Does anyone do any measurements that are representative, eg., 5 A with pulses to over 10A. Then we could get a quantitative comparison between NiMH and LiIon, and maybe more importantly, between different LiIons. At the moment its too easy for people to dismiss the results as subjective, or dependent on how you ride it.
Yesterday I was getting cutouts on the flat after 3 miles, which I wouldn't expect even at full continuous throttle.
Nick
30,837
That's what happens when it's cold and the battery is ageing Nick. Even on the Quando which is fairly easy on the battery I started to get that that at six months old in Winter weather. On all three Li-ions it's been the cold that's triggered too frequent failure for the battery to remain useful.
Wisper Bikes
6,317
2,283
70
Sevenoaks Kent
Li ion
Hi Guys
I have just returned from a very productive few days in China during which time I went to the Lishen factory near Beijing. Lishen produce Li ion batteries for every one from Apple Ipod to Samsung and HP. After having seen Li ion batteries being manufactured from the initial slurry through the many many processes to the final cell, I will never look at a Li ion battery again without being in awe. Did you know it takes 15 days to produce the finished item before another 15 days of charging and testing?
The staffing of the Lishen factory was just as impressive, of more than 7000 staff over 70% are doctors, professors and graduates, this includes the production team.
I met Doctor Wu a wonderful Chinese lady who has been working on batteries all her life and is now with the team of scientists working on Lithium Ion. Having spoken to her and Lishen's marketing director David regarding the new batteries for Wisper bikes I have a far better understanding of the immense complexity of designing and manufacturing these tiny works of art, and how massively important the managements systems are, Suffice to say I did not understand any of the science but they are in general agreement with Flecc's point of view, they have not to date been able to produce lithium ion cells for larger applications that are anything like 100% reliable. The small battery cells that work in mobile phones, computers etc are pretty well bomb proof now but they are still perfecting the larger cells.
The batteries that are being used in the Wisper range now are state of the art and if they are going to be unreliable then we know within a few weeks of use, if they work well for the first 10 to 20 charges and discharges then they will, in the vast majority of cases, continue to give perfect service for the rest of their lives, because of this we are extending the testing periods to cover these first charges. It seems one of the biggest problems is the connection between the cells in the battery, if one of them falls out then the whole battery gradually becomes infective.
Lishen are working on a new Li ion battery cell and connection system along with a new management system that will be ready for testing in the local market in March 2008 and ready for export in October 2008, these next generation ebike batteries will be 10 amp 36v thus saving weight but in the opinion of Lishen will be even more reliable than the 13a version that we are currently using and will have a life of between 1500 and 2000 charges.
The most important point that the people at Lishen made was that in their opinion the only battery worth such massive investment for almost immediate use is the lithium ion battery and although they have new wonders on the drawing board involving nano technology, they will not be available commercially for years.
Please accept my apologies for not being at all technical but I could not even try and explain the science behind these mighty marvels!
On another note we have a 14 amp lithium polymer battery from our second manufacturer, with a wonderful new controller specifically designed and matched for this battery, on trial as I write. Being lithium polymer it is as a little lighter than the hard cased cells and being 14 amp it seems to be able to cope with the huge demands of an electric bike. First tests have indicated that we can pass the 100 kilometer barrier under power assist with a 70kg man on a flat surface and 65 kilometers under power only. There also do not seem to be any of the cut out problems discussed in this thread. (We have not experienced any problems in this area since we introduced the 13a unit.) All safety tests including, piercing, crushing, exposure to heat have been fine, I will keep you posted.
Best regards David
HarryB
1,317
London
Update
Well my battery arrived today and fully charged I took it out for a test ride. What a difference it makes and what a relief to be able to use full throttle again without fear of cut outs, it was even difficult to get the yellow light to show on hills. My old battery was well and truly exhausted.
What I have done is to calculate how many charge cycles the old battery had taken. This was done by counting up my shifts at work and counting one charge cycle as a return trip or 20 miles (although the battery was always charged at work).
The result is quite shocking and comes out at well under 130 cycles. Of course I have used the bike locally but there are times I have not cycled in to work so I think 130 is a fair assumption and a long way short of the claimed 500 cycles. Maybe the battery was faulty after all the first one supplied was faulty (maybe I am unlucky). In April the battery was tested and found to be 8.5Ah so the rate of decline seems to be pretty consistant.
The sooner I get the NiMH the better.
HarryB
1,317
London
Having re-celled an Ezee battery I can say that space inside is very limited, the main body of the case has just enough room for the 6 vertical sticks of 5 cells with room for one more between the detents at the top.
The cells I used were originally tagged but the tags had to go as their thickness added up to about 6mm for the 5 high stack which was too high to fit.
In doing some research into the NiMH cells it seems they might vary in size - from 58mm to 61.5mm (according to some websites). I presume that it is the larger sizes that will have trouble fitting. Interestingly some of the button D cells are quoted at 60mm and they seem cheaper so maybe a solution if 50 cycles don't come up with the goods.
Flecc - just out of interest - do you think that my battery was faulty or do you think that 130 cycles is about it for the Li-ion. I believe you have had three and (with one faulty) and I wondered if you concur with the result. I know it is very difficult to judge what is a charge cycle.
Tiberius
919
Somerset
Hi Harry,
I take it your new battery is a Li Ion. You say the sooner you get NiMH the better, but surely what we would really prefer is a Lithium that was actually reliable.
What's not clear to me at the moment is whether all Lithium batteries have turned out to be a disappointment on e bikes or just some of them.
Anyway, I have just fitted a Cycle Analyst from ebikes.ca so that I can get some quantitative measurements of current voltage and Ampere-hrs rather than the more subjective observations on distance and gradient.
Nick
30,837
I concur with that Hal, and it could be said my case is worse.
Six month equals 182 days, but not cycling every day, having three bikes for the duration and only one of them on Li-ion, that bike was probably used between a half and two thirds of the days. So my experience is 90 to 120 charges, and most of those only part charges no more than a third of the capacity. The total mileage per battery is about 600. Yes really.
The true number of full charges doesn't bear thinking about.
Mind you, single use D cells would have to be only 41 pence each to match my Li-ion cost, so from that point of view still ok. :rolleyes:
Well, you have to look on the bright side, don't you! :D
30,837
Best regards David
No apologies needed David, many thanks for the detailed explanation and update on progress.
I first posted nearly a year ago that larger capacity was the best way to get out of cut out problems with the current technological limitations, so we're very much in tune here. It's interesting though that a return to 10 Ah with better management control is now on the cards, for that's the other solution, amply demonstrated by BionX and Panasonic using top drawer battery management.
I've just been riding such a Li-ion system well into battery empty flashing LED mode while climbing a 1 in 7 (14%) hill on full power mode, without a trace of it wanting to cut out.
So there's hope yet.
I agree that most research investment has to go into Lithium, anything else would be silly, but wish that some production investment could be put into NiMh while a real need for those still exists. It may be yesterday's technology, but tomorrow hasn't arrived yet and we're in trouble today.
carpetbagger
744
18
blackburn
reading between the lines is it possible that the same problem could arise on the powabyke lithium ?
30,837
I've been wondering exactly that, given the power of the Powabyke motor. Perhaps Frank of Powabyke can enlighten us.
carpetbagger
744
18
blackburn
i hope so,i don't fancy forking out £300+ for something that in reality isn't going to be any better than a lead acid
giguana
216
I can tell you where to get 12mah of radio controlled batteries for 180 pounds delivered in 9x12V packs in the UK...I also have a nice lady from China offering me 30 pack crates of batteries for 105 pounds a pack.
