Izzy, sadly just cold water from a hose pipe, although I am in the process of fitting a hot water heater to the outside loo, so perhaps I should extend it to having another outside tap with hot water. There wouldn't be much water pressure, but at least the water would be warm.
Gubbins, Izzy has hit the nail on the head, as the only way of having relatively dry feet, is to cover the top of the boot/shoes to stop the water running down the leg and inside.
I bought a pair of Gore-Tex Shimano winter boots about two years ago for about £130.00 and in truth, I might just as well have flushed the money down the drain. The first ride the water ran down my leg and inside the boot, and despite removing the insoles, they took a week to dry out and stunk! This was a weekly ritual with them, and in the end I just used a plastic bag over my feet when using them.
Luckily they fell apart after a year, and I received a full refund from Wiggle.
If you can find a means of stopping the water from entering, they will be a brilliant boot.
Sealskinz socks are just the same. The water runs down your leg, and straight inside the sock, filling it with water that can't escape. At least the water becomes warm after a while though!
With the refund on the original boots, I bought three pairs of Shimano summer boots, and now just rotate wearing them. The BBB thermal overshoes do a brilliant job of keeping feet toasty warm, and because the boots are summer ones, they dry out very quickly.
As an aside, I'm another that wears spd's. I much prefer being clipped in.
Hard to believe that you can get pleasure from returning from a ride looking like this.
Shimano Gore-Tex boots.
And the overshoes, taken during tonight's ride.
edit...Just remembered another clothing method that keeps the legs fairly warm when conditions turn. Cycling shorts, with a pair of Lidl thermal long Johns underneath. They cost a couple of pounds a pair, so it is no big deal if you only use them a few times, before discarding them. Not that I have yet, but they do end up going a bit on the baggy side after a while. looking at the ankles, I suspect I am wearing them in the second photo. Ankles like Norah Batty!!!
