Throttle use Poll
When do you use your throttle if fitted?
  • Total voters
    103
  • Poll closed .
shemozzle999
2,826
686
It's pity more don't come in, it would be good to get a very large sample which would be more convincing. I'm sure that across the entire UK e-bike ownership, more than twenty times the forum membership, with throttles would be the overwhelming choice.
Agreed, I sometimes check to see how many guests (potential new members) are viewing and I am amazed how many there are and I does not matter personally to me what the overall conclusion is as long as it reflects the true position.
Is it a good idea to remove the my original post contained in the quote?
No need, I've edited my response to include your amended post instead and removed the words "That's because" from my answer. :)
Salad Dodger
13
North Kent
I have only ever used the throttle on my Powercycle once - to propel the bike up a steep bank whilst I walked alongside.
I can't imagine having any use for it in day to day riding. In fact, if the throttle stopped working (unless it took down the whole electrical system) I wouldn't notice.
Jonah
882
246
EX38
I have throttle only and use it when needed (on longer hills / into the wind) never for starting off. My wife never uses her throttle on her Wisper.
Wisper Bikes
6,341
2,297
70
Sevenoaks Kent
I hope you get late flood of votes David to help strengthen your case.
Its just a simple mouse click required, there is no need to make a post.
Thanks Shemozzle, the results and comments are already very useful although the more we have the stronger our case will be.
Regards
David
Wisper Bikes
6,341
2,297
70
Sevenoaks Kent
What happened to the press release the other day about the law changes, I thought it said throttles would be allowed. It seemed slightly vague but said it would allow the Yikebike which doesn't have pedals.
The most important results of the IMCO vote are as follows:
1. Pedelecs with assistance up to 25 km/h would be excluded from the type-approval without specification of a motor output limit. As a result, all 25 km/h pedelecs irrespective of their motor output would become subject to the Machinery and EMC Directive and classified as bicycles instead of mopeds. ETRA (and BEBA) has consistently argued that speed and not power is the determining safety factor.
Today pedelecs with assistance up to 25km/h are excluded from the type-approval, provided that their motor output is limited to 250W. Any pedelec with a higher motor output is subject to the current type-approval procedure and is consequently categorised as a moped. Exclusion of this category from the type-approval will make it a lot easier and a lot cheaper to develop vehicles with a higher motor output for instance to carry cargo or to be used in hilly areas.
2. E-bikes, that is bicycles with an auxiliary motor that can propel the vehicle even if the cyclist is not pedalling , would be excluded from the type-approval provided their speed is limited to 25 km/h and their weight to 25 kg. Thanks to the weight limit, these vehicles would in the case of an accident present no more potential risk of injury than a conventional bicycle or a 25 km/h pedelec. Therefore, it is logical to exclude them from the type-approval in order to make them subject to the same regulatory framework as pedelecs 25 km/h. This exclusion also provides legal certainty for innovative light electric vehicles such as Yikebike.
Also excluded would be self-balancing vehicles, such as Segway, and light electric vehicles without a seat, such as Trikke, with a speed limit of 25 km/h. This would finally make an end to the uncertainty about the legal status of these vehicles.
All welcome news David, but subject to being passed by the UK parliament as well before we can benefit. That's the worrying stage for me, given our history of excessive regulation. The e-bike/pedelec 14 years lower age limit for example.
Wisper Bikes
6,341
2,297
70
Sevenoaks Kent
It is good Tony, but unfortunately we all are having to work without the assistance of organisations such as the BAGB who have recently written to Norman Baker to oppose all the changes. They seemingly want electric bicycles in general to as low powered as possible, without obvious advantages of a throttle and certainly not made in China!
Unfortunately most of these "electric bike experts" are not in touch with the wants or needs of the electric bike buying public yet seem to have the need to interfere.
Best regards
David
NRG
2,592
10
That lowish 25Kg weight limit may be an issue when implementing more powerful motors for a number of reasons....
z0mb13e
578
Dorset
Interesting that the Segway et al would be made legal too (if I read that right)...
As for my throttle usage, I am currently using full throttle as my pedelec sensor is on the fritz and I've been too lazy to try and fix it. That and my battery isn't as powerful as it once was (full throttle de-restricted can just about manage 15mph).
However a throttle has been invaluable for the following reasons:
Stability. Riding on sand/snow/ice, provides stability. I can stop pedalling and lower my centre of gravity whilst still moving forward. Also I find that I am able to ride much closer to the kerb when forced to (usually by a car/bus pulling in too soon ahead of me) as I don't have to worry about catching a pedal on the kerb. That has saved my bacon a couple of times.
As has been mentioned before a throttle is great for getting moving quickly, particularly when at the front of a queue of traffic and on a hill. Being able to do this is much safer than trying to stand up and mash the pedals to get going up hill from a standing start.
Speed control. I can move slowly yet consistently on busy cycle paths and not get into that horrible situation where you are in too high a gear and can't maintain forward motion and you end up standing on the pedals and trying to change gear and it all goes wrong and you end up in a heap on the floor (just me?).
Speed boost. I have used throttle to get me out of trouble on roundabouts (it almost always seems to be roundabouts), being able to accelerate quickly is great for getting out of the way of motorists who race round.
I have also used the throttle as a get me home feature when my gears froze in 1st.
While I could live without a throttle I can't see any good reason to remove its use from future ebikes.
Best regards
David
That's precisely my worry David, in Britain we are plagued with nanny-state people obsessed with eliminating any chance of a perceived risk by means of legal restriction. This EU measure if passed there is just the sort that will attract the attention of these types.
As an illustration, we've recently had the AA vigorously opposing the eminently sensible reduction of MOT tests to two yearly intervals. Where else in the world would a motorist's organisation oppose help for financially hard pressed motorists? Britons will be self-flagellating next at this rate.
torrent99
395
36
Highgate, London
My knees are buggered so I always use the throttle, or should I say used the throttle as my Wisper has been off the road for the last couple of years as ,my knees couldn't cope with even the very light spinning.
Ideally I'd want a 15mph moped/bike that could be parked up like a normal bike...it looks like the proposed regulations would allow me to convert the Wisper to such a beast provided I can stay under the 25kg.
The easy way to stay under 25 kilos with a more powerful motor is to have a smallish main battery with an auxilliary battery option. Only the small main battery would count towards the specification weight.
z0mb13e
578
Dorset
Self balancing machines are specifically excluded, so Segways will not be legalised.
I read "Also excluded would be self-balancing vehicles, such as Segway, and light electric vehicles without a seat, such as Trikke, with a speed limit of 25 km/h. This would finally make an end to the uncertainty about the legal status of these vehicles."
...in the context of...
"Pedelecs with assistance up to 25 km/h would be excluded from the type-approval..."
...and...
"E-bikes, that is bicycles with an auxiliary motor that can propel the vehicle even if the cyclist is not pedalling , would be excluded from the type-approval..."
So are they being excluded from type approval or from mention in the debate on the directive?
I think it means from type approval, in other words, legalised. The 25 kg limit would apply of course since they are not pedelecs, no pedals.
I think so too, they look very heavy to me, especially the larger wheeled mixed terrain one.
Wisper Bikes
6,341
2,297
70
Sevenoaks Kent
That is also my understanding, Segway however is very much heavier than 25kg so would still need to be type approved whereas the YikeBike penny farthing without pedals would be be excluded from type approval and therefore allowed.
The good news is those who like to use throttle on their pedelec would be allowed to do so. This coupled with the 1kW maximum power and 25kph max speed limit would give a means of transport to those with bad knees, hips or other problems that cannot pedal able to navigate almost any hill. Thus opening up cycling to many more than in the past. Good news all round in my opinion!
All the best
David
bigroy
73
17
Fife Scotland
over the last 6 years I have lost count how many kits I have fitted. but most people about 85% just want a throttle fitted.
